Old 09-24-2010, 10:54 AM   #1
geoff135
geoff135's Avatar
Drives: 2SS/RS/ 16 4runner/74 TR6
Help! ECU locked?
Had LT headers installed, car is at tuner right now. He's called twice to say he can't get the car to keep any changes. He'll put them in, they appear to take, but than the car will start to run in limp mode. It's almost like the ECU is locked. He was able to turn of the CE, etc, just unable to make any other changes stick. I bought the car new, so I know the ECU program is still stock. Its a '10 SS M6, any one have any ideas?
Thanks
Tuner has done 5th gen camaros before without running into this issue
geoff135 is offline   Reply With Quote
Old 09-24-2010, 11:00 AM   #2
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
One of the many good tuners on here will be able to help you just as soon as one of them read your post. Good luck.
2010 2-Tone is offline   Reply With Quote
Old 09-24-2010, 11:01 AM   #3
DSteck
Drives: 2006 Corvette Z06
After reading the file, pull the battery cable for a few minutes.
What's he using to reflash?
Also... are any codes showing up?
DSteck is offline   Reply With Quote
Old 09-24-2010, 11:07 AM   #4
Steve@Vectormotorsports
Drives: Firehawk
X2?
Steve@Vectormotorsports is offline   Reply With Quote
Old 09-24-2010, 12:31 PM   #5
geoff135
geoff135's Avatar
HP tuners for the reflash, he said it's not showing any codes, just the msg engine pwr reduced
Old 09-24-2010, 12:40 PM   #6
DSteck
Is it happening as soon as you start the car?
E-mail the stock and modified file to steckdw at gmail dot com.
Old 10-04-2010, 12:04 PM   #7
Frost
Frost's Avatar
Drives: GM anything
Thanks
uhhhh..
you should ask him how he was able to even get started and READ the PCM if it was locked..
Frost is offline   Reply With Quote
Old 10-04-2010, 08:35 PM   #8
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Must use HPT Beta to read/write 2010 Camaro.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
is it possible that bolt ons can cause the ecu to change mikeSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-19-2010 04:46 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 11:25 PM
ECU Flash Counter? BlackinBlack Tuning / Diagnostics -- engine and transmission 67 11-16-2009 02:13 AM
ECU Reset on Camaro SS rauhaus camaro 5th Gen Camaro SS LS LT General Discussions 9 10-14-2009 12:18 PM
ECU Pics? Jonmalibuss Camaro Photos | Spyshots | Video | Media Gallery 8 05-14-2009 03:55 PM
