Old 10-25-2010, 11:27 AM   #1
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
Questions before Maggie install.
November 15th my car is scheduled to go in for upgraded heads and TVS 2300 install. I have a couple of questions .
I see alot of the supercharger builds use a 160 degree thermostat. In my quote,they are not calling for a different thermostat. Should I specify I want one or just keep the stock one?
Also,I have a CAI intake installed. Is this compatible with the Maggie or does it need to be changed out? (If it does,I have no problem with that as it is easily saleable).
Thanks for the help.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 10-25-2010, 02:17 PM   #2
Jessika
Drives: Anything Blown
I would recommend to ask the shop that is doing the install about the thermostat. With the stock kit & stock boost, we recommend keeping the stock thermostat but the heads may change that.
Also, what type of CAI do you have? I have a rotofab on my 6.0L and was able to modify the intake tube to work with the magnacharger.
Jessika is offline   Reply With Quote
Old 10-25-2010, 03:06 PM   #3
papabearcamaro
I will be using PRC L92 heads....stainless valves and .675 lift dual springs
FAST 65lbs LS7/L92 Precision Flow injectors
GM head gasket
ARP 12pt head stud kit.
Pully down to 3.6
10% overdrive 8 rib crank pullyNGK copper plugs
crankshaft pinning kit
secondary fuel pump
The air intake that is on now is the Cold Air Inductions unit (plexiglass top,enclosed)
If anyone notices anything wrong or something that can be improved in this package please let me know. I appreciate all the help offered.
Old 10-25-2010, 03:32 PM   #4
SC2150
You need a good FI configured oil separating can as well.
Old 10-25-2010, 03:40 PM   #5
Jessika
My suggestion is to talk to the shop doing the installation...
They should be able to fill you in on any other recomendations, but a oil catch can is always a good idea, IMO.
Old 10-25-2010, 04:54 PM   #6
Slowhawk
Drives: 1999 Trans Am
We ussually throw in the 160 t-stat and NGK TR6 plugs. Mag recommends stock plugs but we have seen alot of problems running stock plugs on FI.
Slowhawk is offline   Reply With Quote
Old 10-25-2010, 05:01 PM   #7
Jessika
Stock plugs are recommended for 6lb boost applications, also they are needed for the EO certification/emissions.
If it isnt a stock setup blower, then the advise should be that of the tuner/installer
Old 10-25-2010, 08:23 PM   #8
Total_Perf_Eng
Total_Perf_Eng's Avatar
Drives: Corvette
Send a message via AIM to Total_Perf_Eng
We ALWAYS run a 160* t-stat, and NGKTR6, gapped at .035". We have an LS3 Camaro in the shop right now that has the base kit, and 4 out of 5 times on the dyno, it knocked, and pulled timing. We switched to TR6's, and we made the best power, with 0 knock retard.
Total_Perf_Eng is offline   Reply With Quote
Old 10-25-2010, 08:29 PM   #9
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
"secondary fuel pump"? Is this a dual pump, BaP or something else?
Jchaluja is offline   Reply With Quote
Old 10-25-2010, 10:54 PM   #10
rgrizzard
Drives: Wanting New Camaro
The LS engines run better in the 180-190 range. I would ask for a thermostat in theat range and the tune to match it.
rgrizzard is offline   Reply With Quote
Old 10-26-2010, 01:22 AM   #11
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
Watching
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 10-26-2010, 09:46 PM   #12
papabearcamaro
Bump for any more thoughts or comments.
Old 10-26-2010, 09:52 PM   #13
GJG
GJG's Avatar
Drives: 2SS
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
P0068 dtc after Maggie install? victoryred1ss Forced Induction - V8 6 09-09-2011 09:35 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
maggie questions drkllr Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 03-31-2010 07:32 PM
SCT TUNE after Maggie install racer778 Tuning / Diagnostics -- engine and transmission 3 03-23-2010 02:22 PM
Cam install questions Fritostud Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 03-22-2010 01:47 PM
