View Poll Results: Stands or no stands
With stands 15 20.83%
Without stands 57 79.17%
Voters: 72. You may not vote on this poll
Old 10-31-2010, 09:16 PM   #1
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
stands or no stands?
Is it better to put it on stands or store it without?
Airaid Intake And Solo CatBack Solo Highflow Cats
noisemker is offline   Reply With Quote
Old 10-31-2010, 09:19 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i have always thought you should keep the car the way its made to... it wasn't design to be on stands for months... thats just my thoughts
Old 10-31-2010, 09:55 PM   #3
spyderbuddy
get the tires off the ground. They tell me the best way is with the suspenion hanging (unloaded).
Old 10-31-2010, 10:08 PM   #4
kylenewman
Drives: 2010 Camaro 2SS
Everything I've read for the Camaro says not to store it with the suspension unloaded as this can cause damage. The suspension is meant to be loaded and can be damaged when unloaded for long periods of time.
kylenewman is offline   Reply With Quote
Old 10-31-2010, 10:16 PM   #5
95cam86roc
Legends NEVER die!!
Drives: 1986 Iroc-Z LSx
I was always told to store the car with the suspension loaded as was mentioned by kylenewman.
95cam86roc is offline   Reply With Quote
Old 10-31-2010, 10:36 PM   #6
Sandor
Chevrolet Performance
Sandor's Avatar
Drives: Camaro Chroma
The main reason people usually use stands is to prevent tire flatspotting. You can easily do that by simply moving the car each month, forward a foot one month then back a foot the next. No need for stands.
Sandor is offline   Reply With Quote
Old 10-31-2010, 10:37 PM   #7
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
INTIMIDAT3R is offline   Reply With Quote
Old 10-31-2010, 10:38 PM   #8
Viper595
Redline drop, or go home
Viper595's Avatar
Drives: 2010 Camaro SS
hmm. this one is tricky. in my humble opinion, it would be best to leave the car stored without jackstands, but make sure your tires are properly inflated at all times, as not to let them get flat-spotted from sitting with low air pressure. as far as the suspension goes, control arm bushings, sway bar link pins, struts and balljoints are all perfectly fine under loaded conditions, as this is how they are when the vehicle is operated, so simply letting the car sit would be perfectly fine. also make a point to start the vehicle at least once a month, let it idle to operating temperature before shutting it off if it's being stored over the winter.
Viper595 is offline   Reply With Quote
Old 10-31-2010, 10:54 PM   #9
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
on jackstands, with the jackstands supporting the car through a suspension component, as to compress the suspension, but still leave the wheel/tire off the ground... such as the lower control arm.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 10-31-2010, 11:07 PM   #10
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
I guess I must be way out in left field here. I havenever worried about the "flat spot" stuff when the car is only going to sit for a couple of months. I have had a collector car for the past 12 years.
When I stored the car, I changed oil, inflated tires to proper pressure, used Sta-bil in the tank, started it every couple of weeks, and that was it.
Yeah, the tires had flat spots on them, but when I drove each one of my collector cras, the flat spots were gone within the first 15-20 minutes of driving. Oh, the horror ---- NOT!
Had the car been stored for years, yeah , then maybe support to prevent permanent damage may be warranted. But for a couple of months. Nope, not in my experience.
It is much better to have the car sitting on it's suspension as mentioned by several previous posters on this site. Extended fully or compressed fully, may cause problems. THat is something to look out for.
Besides, if you have a nice clear day in the middle of Winter and the salt has been washed away, it sure is nice to be able to easily, take your car out for a quick cruise.
Just one person's, take.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name.
greenrail is offline   Reply With Quote
Old 10-31-2010, 11:10 PM   #11
20Camaro11
20Camaro11's Avatar
Drives: SS
Had the car been stored for years, yeah , then maybe support to prevent per,ament damage may be warranted. But for a couple of months. Nope, not in my experience.
I agree with this post. I have seen plenty of fine car collections, and none of them were on jackstands with the all the other overkill unecessary procedures. I say keep it simple....
20Camaro11 is offline   Reply With Quote
Old 10-31-2010, 11:14 PM   #12
greenrail
Comic Curmudgeon
greenrail's Avatar
Rosie is my fourth "toy" car in the last 12 years. Flat spots were never permanent. Always went away during the first major drive every spring. Never came back until the car sat in storage each year.
Not really any problem.
1979 trans am
1974 corvette
1998 camaro ss
2010 camaro 2ss
Old 11-01-2010, 11:28 AM   #13
GhostSS
Chuck
GhostSS's Avatar
Drives: 2010 Silver Ice Camaro SS
Have been storing my cars on the tires for years. Also good in case of an emergency and you need to quick get out the car e.g. Fire.
"Work hard and spend it, you can't take it with you!"
Other Rides: 2008 Porsche 911 Carrera, 1964 Corvette Roadster & 2001 675HP Supercharged Corvette (Corvette By Chevrolet / Horsepower By: East Coast Supercharging)
cdavis@adaptivesolutions.com
GhostSS is offline   Reply With Quote
Old 11-01-2010, 11:38 AM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I've been winter storing for the past several years in my insulated, UNheated garage, on concrete, using only Stabil in a full tank, a battery tender, and car cover. Never had an issue. Flat spots are typically more prevelent on a high performance, low sidewall tire.These Pirellis are at best borderline for that. I had no flat spot issues last winter and don't expect to after this winter. See you in the spring.
tire stands to prevent flat spots Darth_Emma Wheels and Tires Talk Sponsored by The Tire Rack 11 06-28-2010 09:03 AM
Custom Car Show Display Stands 01pewterz28 Members Classifieds - Non-Automotive 10 06-04-2010 05:37 PM
Whats the best place for Jack stands for winter storage? esperman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 10-26-2009 12:05 PM
Jack stands ROD1 5th Gen Camaro SS LS LT General Discussions 14 10-24-2009 10:03 AM
