Old 11-08-2010, 05:46 PM   #1
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
DT Shorty install today-Engine light now on
Hello,
Had DT Shortys installed today and engine light is now on. Autozone diag shows Lean Condition Bank 1. Other mods are CAI intake and Borla axleback. Any ideas how to fix (without getting aftermarket tune)?
Old 11-08-2010, 05:58 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
WOW !!! You are the first person to get a light ... Check your O2 sensor connections on the cats ...
Old 11-08-2010, 06:15 PM   #3
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Originally Posted by mclark10 View Post
Hello,
I would just clear the code for now and disconnect the battery cable for a few minutes to reset the trims. It may never return. If it does, then you may have to deal with it.
2SSCAMARO is offline   Reply With Quote
Old 11-08-2010, 06:46 PM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
and for leaks at the manifold and downpipes connections as they will draw in air causing a false lean condition...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 11-08-2010, 06:59 PM   #5
FUN4JT
FUN4JT's Avatar
Drives: 2010 SSRS, Victory Red, 6 speed
Have DT shorties, hi-flow cats, "X" pipe, CAI and canned Predator tune, zero codes to date after approximately 9k miles. Ditto on checking for a air leak at the head/headers or the header/cat flange and make sure the o2 sensors are completely plugged in. JT
FUN4JT is offline   Reply With Quote
Old 11-08-2010, 07:29 PM   #6
Slowhawk
Drives: 1999 Trans Am
Make sure the driver side front 02 is plugged in. After that it might need an 02 sensor. I've had 2 cars in the shop with the same code.Both had other shops do the install and come to find out the 02's were stripped(common factory problem) and the shops used a torch to get them out.They fried them.
So,reset. If the codes come back quickly change the 02 or go to a shop to diagnos it properly. A lean code means it's dumping 25% more fuel on that side of the motor.
Slowhawk is offline   Reply With Quote
Old 11-08-2010, 08:08 PM   #7
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
no codes thrown or SEL on mine either with the DT shorties, even with the hiflow cats installed. yep, like slohawk said, you're getting more fuel on that side of the motor.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 11-08-2010, 08:08 PM   #8
ZED SLED
ZED SLED's Avatar
Thanks for the input everyone. I have to take it back tomorrow to have the the bolts re-torqued so I'll have them check for leaks and O2 issues and reset.
Old 11-08-2010, 08:27 PM   #9
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Tis the season for engine codes let me tell ya!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 11-11-2010, 05:49 PM   #10
Moody'sSS
Moody'sSS's Avatar
Drives: IOM 2SS 2010
Problem fixed?
OBX headers/Flowmaster AT exhaust/C.A.I. intake/ADM race scoop/RX catchcan/Black replica wheels/Vmax throttle body/JRE tune
Moody'sSS is offline   Reply With Quote
Old 11-11-2010, 06:29 PM   #11
Ivan @ Southwest Speed
Over 100 sets sold and yes, you are the first sir. I need to send you a TShirt.
Looks like you have alot of the same responses. I'd think that there is a leak upstream without a doubt.
Originally Posted by moodysilver10 View Post
Problem fixed?
Ditto....call me or let me know if you need any support at all.
JBA shorty headers installed, engine light on Acebeforejack Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-27-2010 11:41 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
Check engine light after cai install 2010CamaroOutlaw Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 01-08-2010 12:18 AM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
