Old 11-14-2010, 11:22 AM   #1
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
Cool flywheel, clutch and rear-end upgrades
I'm having a supercharger added and already have headers and performance exhaust. I'll be at about 600 hp when it is complete. The camaro wiki says the stock tranny is rated to 430 lbs/tq and I'm going to be way over that. I know I would benefit from a clutch/flywheel upgrade but it is necessary? Will I smoke the clutch without it? If I upgrade the clutch/flywheel to hold all the new torque will the stock rear end gears handle it?
S-eatin-grin is offline   Reply With Quote
Old 11-14-2010, 12:01 PM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
New clutch/flywheel along with halfshafts *should* be good enough. If you want to go extreme then you can beef up the transmission internals, output shaft, drive shaft, 9 inch rear, and halfshafts for a bulletproof setup. That will cost more than your supercharger though.
ackeight is offline   Reply With Quote
Old 11-14-2010, 12:09 PM   #3
1 bad azz ls3
1 bad azz ls3's Avatar
Drives: 2010 camaro ss
your stock clutch and rear end will hold 600hp. save your $.
1 bad azz ls3 is offline   Reply With Quote
Old 11-14-2010, 12:14 PM   #4
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
A good follow up question would be, how do you use your car?
Old 11-14-2010, 12:22 PM   #5
oldfriend
Drives: Fiat 500 E
2SS
GARAGED 24/7 ,NO PROBLEMS
Old 11-14-2010, 01:07 PM   #6
S-eatin-grin
I don't drag the car at any tracks/courses or do launches but I do get on it and eat a few mustangs from time to time
Old 11-14-2010, 02:58 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
A clutch and flywheel upgrade would not be a bad idea but you aren't to the point where you need to be worried about beefing up much else, especially if you aren't hitting the track. You will probably want to make some suspension upgrades to help get that power to the pavement.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Thud from rear end? booenson V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 06-06-2010 10:15 AM
Noise from rear end jhutch Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 05-10-2010 03:59 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
