Old 11-23-2010, 09:55 AM   #1
Ron@Vengeance
Ron@Vengeance's Avatar
Drives: 2013 Artic White GrandSport
Vengeance Racing installs Whipple 2.9L Supercharger on 2010 Camaro.. Results inside!!
This was our first Whipple Install for the 2010 Camaro. We have built several dozen TVS2300 powered Camaros so we were quite anxious to see how the Whipple compared in quality and performance.
The Car: STOCK 2010 LS3 Camaro
The Modifications:
Whipple 2.9L Supercharger system
FIC Modified LS3 Fuel Injectors
Kenny Bell Boost Pump
American Racing 1 7/8 Stainless Longtube Headers
CATTED X pipe
Installation/Tuning by Vengeance Racing
STOCK AIR BOX
STOCK CATBACK
12 psi peak
Pump gas
The Results: 613RWHP/574RWTQ... This is a gain of 251RWHP/209RWTQ over stock. I am confident we could pull another 20rwhp or more out of this combo with a new clutch. The customers clutch did not like the added power AT ALL and let us know by the smell it put off after each run. We stopped tuning with a VERY conservative # to keep the clutch in tact for a little while for the customer.
Fit & finish is incredible!!! The kit itself is very detailed and includes EVERYTHING needed for install down to a replacement K&N Panel filter. The best thing I can say about this supercharger system is that after 6 dyno pulls I could lay my hand on the blower and it was warm to the touch. Coolant temp in the intercooler was also warm to the touch but would not burn you...
Below are some pics of the completed installation.
Vengeance Racing is now a dealer for Whipple Superchargers!!! We believe this is the best available option to date for the 2010 Camaro!!! Give us a call for incredible pricing!!!!
Ron@Vengeance is offline   Reply With Quote
Old 11-23-2010, 10:03 AM   #2
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Great results Ron; This thing is awesome;
I wonder two things:
a) What would be the numbers without the headers?
b) What would be the numbers if you had also added CAI to this combo?
Z_Rocks is offline   Reply With Quote
Old 11-23-2010, 10:27 AM   #3
stanwilliams
3000 hp 648 ci beast
stanwilliams's Avatar
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3
What size pulley were you using?? Was that on 91 oct fuel or 93 or??
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list.
stanwilliams is offline   Reply With Quote
Old 11-23-2010, 10:45 AM   #4
SC2150
Nice Job Ron!
Old 11-23-2010, 10:51 AM   #5
KeeBee
Drives: 2011 Camaro SS/RS, 70 1/2 SS Camaro
Good work. Would like to see a video to hear how it sounds.
KeeBee is offline   Reply With Quote
Old 11-23-2010, 10:52 AM   #6
Awesome numbers
Old 11-23-2010, 10:57 AM   #7
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Nice Job Dude! These Whipples really rock! My L99 picked up 172rwhp from just adding the whipple and a retune. Speaking of those intercooler temps, I found the same thing to be true at the dyno and the strip. Every run I hooked the car stayed w/ in a 1 tenth spread. Very little heat soak.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 11-23-2010, 11:17 AM   #8
Dr Jkel
Roll Tide
Drives: 2010 2SS RJT/BLK 6Spd Man
Awesome job, those numbers are incredible. I am amazed at how much power it has.
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 11-23-2010, 11:54 AM   #9
camaro692
Drives: 2010 Camaro SS, G8 GT, HD FLHRX
Im sure this has been covered but is 12psi safe?
[SIGPIC][/SIGP
camaro692 is offline   Reply With Quote
Old 11-23-2010, 12:01 PM   #10
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Nice numbers....What was the timing at on that...seemed like it was fluttering on the dyno a bit on upper rpm's. But sure seemed to be producing solid and strong results.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-23-2010, 12:52 PM   #11
navyblueSS
Drives: 2002 Camaro SS
Awesome, very nice gains.
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 11-23-2010, 07:42 PM   #12
jbusmc1986
on the hunt
Drives: ...
wow, impressive numbers on a mostly stock car... but I am just curious,wouldnt you want to at least run water/meth for safety at 12psi on a stock motor?
jbusmc1986 is offline   Reply With Quote
Old 11-24-2010, 09:55 PM   #13
Ron@Vengeance
The only thing "fluttering" was the clutch disc ... As I mentioned above we were having clutch issues and stopped the tune short of this combos potential. Timing was right at 14* and air fuel was 11.20s.... There is more left in it
Old 11-24-2010, 10:16 PM   #14
BigDan
Drives: bug
Nice number's and nice choice on the Black Whipple, it looks right at home on top of the engine. I really like the jack shaft cover, I always though about the miss fortune of some guy wearing a neck tie leaning over a Maggie with the engine running and getting choked out or worse.
I like hearing about the burnt clutch, that just goes to show the awesome power of a Twin Screw vs TVS. You Whipple boy's are sure in for a treat, good and better thing's come to those who wait.
I'm definitely going Whipple but I'm on the fence between the more practical 2.9L or the 3.4L. I'd like to have the 3.4L just for bragging right's but it requires more mod's to shine.
BigDan is offline   Reply With Quote
2010 Camaro x FOUR..... Bolt on/Bolt on/Bolt on/Cam & Header/TVS230 results inside!!! Ron@Vengeance Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-10-2010 01:49 PM
Vortech Supercharger Systems for 2010 Camaro Official Release Brian@Vortech Forced Induction - V8 98 02-20-2010 12:04 AM
2010 Camaro Stock Vs American Racing/Magnaflow Vs Vengeance Stage II Cam Kit..Results Ron@Vengeance Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 01-14-2010 02:00 PM
