Old 11-24-2010, 08:41 AM   #1
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Race Fuel
Right now I have the Vortech V3 with canned tune on a LS3 pushing 525 WHP, what if any gains would I see by filling up with some 100, 105 octane fuel? Any changes to the car need to be made?
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 11-24-2010, 08:58 AM   #2
lrc250
480 HP 2010 2SS
lrc250's Avatar
Drives: 2010 Camaro 2SS
Unless you plan to add timing to your tune then you are basically wasting your money on expensive fuel.
Without data you are just another person with an opinion.
1100 :10/15/08
3000:3/2609
3300:4/18/09
3400 (broadcast)April 25, 2009
3800 (produced):May 4, 2009 #7470
4200 (Shipped): June 1, 2009
5000 (At Dealer) June 9,2009
374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg.
lrc250 is offline   Reply With Quote
Old 11-24-2010, 09:10 AM   #3
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Bingo! exactly right in the above statement.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-24-2010, 09:15 AM   #4
ZuluKilla8
ZuluKilla8's Avatar
what I thought, grazi
Old 11-24-2010, 10:33 AM   #5
jrpxxii
jrpxxii's Avatar
Depending on your driving habits and budget, you can see great benefits from running race fuel. I only run VP MS109 race fuel which is an oxygenated fuel and really allows me to see results with a specific race fuel tune. For majority of people this just isnt economical but I am only focused on extreme performance as I am an adrenaline junkie and my build isnt the normal modifications but race fuel does have its advantages and did I mention SMELL of race fuel? LOL
Old 11-24-2010, 11:24 AM   #6
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
For street driving only, do not waste your money. For a day at the track, a few gallons of 104 added to your tank can help in preventing the ECM from pulling timing when moderate detonation occurs because of running let's call it "stale or deficient fuel that has some lesser octane characteristics". By preventing the ECM from pulling timing, you are in essence gaining performance you otherwise would have lost.
2SSCAMARO is offline   Reply With Quote
Old 11-25-2010, 01:41 AM   #7
Blitzman
173rd Paratrooper
Blitzman's Avatar
Drives: Summit White SS
Q16 smells delicious though...
Jeramey - 715rwhp
Vortech YSI - 10Rib
CTS-V Dual Fuel Pumps
American Racing Headers
Thunder Racing Cam
Walker Bullet Exhaust
DSS 1400hp Axles
Barton Industries Shifter
ADM Boost/AFR Gauges
Blitzman is offline   Reply With Quote
Old 11-25-2010, 08:33 AM   #8
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
You would drink race fuel if they'd let you...
But yeah, all these guys have great advice. Race fuel/octane is only necessary if you are going to run aggressive timing or higher than normal boost levels.
Contrary to popular belief if you don't change your engine parameters you will actually LOSE horsepower running race fuel. My friends at C5Fest did that when they put in a bunch of 110 octane bought from SGMP between rounds but ended up not having enough time to go back to the pits and bump the timing. They slowed from an 11.1 to an 11.3. Oops.
Old 11-25-2010, 08:39 AM   #9
2010 SS RS
2010 SS RS's Avatar
mmmmmm the smell of race fuel is like bacon and pancakes in the morning to me....They need to make scratch and sniff or air fresheners with that glorious smell.
Old 11-25-2010, 09:04 AM   #10
Blitzman
173rd Paratrooper
Blitzman's Avatar
+1
Jeramey - 715rwhp
Vortech YSI - 10Rib
Thunder Racing Cam
DSS 1400hp Axles
Old 11-25-2010, 11:27 AM   #11
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
"I love the smell of race fuel in the morning. The smell, you know that gasoline smell, the whole race track. Smelled like victory."
Old 11-25-2010, 11:41 AM   #12
speedster
SST...
speedster's Avatar
Originally Posted by Blitzman View Post
+1
+10
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
JRE FUEL SYSTEM UPGRADE EDELBROCK SUPERCHARGERS JANNETTYRACING Forced Induction - V8 91 05-11-2011 10:35 AM
Check engine light on Boricua Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-28-2010 01:12 AM
New Fuel Economy Rules Urthman General Automotive + Other Cars Discussion 3 04-02-2010 02:43 AM
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com Redshift Audio / Visual / Electronics/ Gauges / Nav 0 07-01-2009 08:56 AM
