Old 12-07-2010, 04:11 PM   #1
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
Differential Fluid: Special Edition Question
So because of Camaro5, I go to my local fluid-change establishment and tell them that although my car only has 19,000 miles, the differential fluid has been showing up very dirty amongst members of the fifth-gen Camaro Forum (yes, that was THE Fifth-Gen Camaro Forum) and could they change it. The tech stated they could but it might be a warranty violation(!) to do so, and to contact GMAC customer support. 3 emails later, they still haven't called me like they assured me they would. Seems like a lot of rigmarole to change out some fluid. Imagine the hassle if you had to do this for an oil change.
So. Question.
Are they right and is it a warranty violation for another establishment to change out the fluid?
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 12-07-2010, 04:28 PM   #2
JoeP@TeamBeckyD
JoeP@TeamBeckyD's Avatar
So. Question.
The key is using the correct fluid that is shown on the tag and documentation. It can void the warranty if the wrong fluid is used.
Old 12-07-2010, 04:31 PM   #3
CamaroFemme
That's what I THOUGHT, but this place seemed downright SKITTISH.
Okay, so, bottom line: warranty intact as long as correct fluid is used?
Old 12-07-2010, 05:00 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Yes.
Straight from the manual.
"Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 89021677
and Friction Modifier 1052358, in Canada 89021678 and
Friction Modifier 992694)."
Also Mobil1 75w-90 LS is the same as the GM stuff. In fact if go to the parts section and give them that parts number, some dealers will give you a bottle of Mobil1 75w-90 LS.
Old 12-07-2010, 07:54 PM   #5
rydahog
rydahog's Avatar
Drives: camaro ss
If you use the wrong fluid its no go on the warranty..but you CAN change it yourself, as others have posted, or get a place to do it. Keep receipts..
As similar situation occured many,many years ago, HD..(motorcycles) was trying to tell owners of their bikes that you could use ONLY hd oil....well some woman rider took them to court for this..and the court ruled in her favor..saying words to the effect...If you are going to require the consumer the use ONLY your product (oil) in order to keep their warranty in tack, then you have to SUPPLY the oil for FREE!
They (HD) dropped the requirement.
rydahog is offline   Reply With Quote
Old 12-07-2010, 08:04 PM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I believe it's also stated in literature that fluids like diff and transmission are "lifetime" fills from the factory under normal driving conditions. At face value that could be misinterpreted as "don't change".
Old 12-07-2010, 08:12 PM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Similiar stories for snowmobile manufactures, that use to require only their oil to be used in the engine. Now you just need to use an appropriate equivalent.
Old 12-07-2010, 08:15 PM   #8
JoeP@TeamBeckyD
You are correct.
Old 12-07-2010, 08:41 PM   #9
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 12-07-2010, 10:32 PM   #10
96/10SS
96/10SS's Avatar
Drives: 2010 2SS Orange w/ Grey stripes
what about if you use royal purple with the modifier already in there? does tht void the warranty?
96/10SS is offline   Reply With Quote
Old 12-07-2010, 11:41 PM   #11
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
I dont think Royal P is on the "GM list"
Plus, their modifiers made my diff chatter. Dumped it out and ran Mobil 1 with GM modifiers, and the problems went away,
Redemption is offline   Reply With Quote
Old 12-08-2010, 01:52 AM   #12
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
No it won't void the warranty. The Chevy dealer in Loveland, CO that changed my diff fluid used Royal Purple MaxGear, right out of their parts room.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 12-08-2010, 10:09 AM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The dealer doesn't have a say when it comes to voiding a warranty. With that said, Royal Purple is NOT on GM's list of approved lubricants. If GM decides to test the lubricant (which they have been known to do in cases of failures) and finds Royal Purple in the rear diff. GM will deny the warranty claim even if your dealer put the lubricant in there.
Old 12-08-2010, 10:29 AM   #14
68blk/yel396
68blk/yel396's Avatar
Drives: 2011 RJT 2SS/RS
I had my dealer check mine at 10K and it was dirty, so they recommended it to be changed. I agreed. Kinda hard to get into a warranty issue if you approach the problem this way and have the dealer involved.
Bottom line................if it dirty you want it changed. Some members of our Camaro club had theirs checked and the fluid was clear. More had it checked by dealers and had it replaced due to the darkened appearance, like me.
68blk/yel396 is offline   Reply With Quote
Change your differential fluid! Shift Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 09-27-2015 08:03 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
2010 Chevrolet Camaro Synergy Special Edition Available Now In The Middle East ketel0ne 5th Gen Camaro SS LS LT General Discussions 0 07-05-2010 05:18 PM
Rear Differential fluid Mobil 1 or Royal Purple, and motor oil discussion. 2010 Bumblebee V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 05-08-2010 06:34 PM
Which special supercharger Camaro edition would you choose? panic Forced Induction - V8 8 09-16-2009 02:56 PM
