T6060 upgrades
what kind of power can the stock transmission hold? Where should I be looking to upgrade other than the clutch?
![]() ![]() ![]() Drives: 04 Silverado Join Date: Jun 2010
They can barely handle stock, and the synchros dont like missed shifts
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Ditto on that!!! I missed a shift once ( at the strip) and now 6th gear likes to jump out sometimes. If your in 5th, I push the clutch in pull it down in neutral put back in 5th then go to 6th, no problems. But if I go from 5th to 6th jumps out.
BAMF SS
it's rated from the manufactorer for 600 hp
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
Is it true that these transmissions aren't really suited well for the strip, even with upgrading it. Just trying to learn more about the options out there before I make a decision.
#6 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I have broke the output shaft already.
Looking to up-grade it. |
#7 |
me to, already had that one taken care of.
#8 |
In The Circle
The Driveshaft Shop is working on a new mainshaft. There are provisions in the case for one more bearing on the mainshaft. GM squeaked out an omitted it.
#9 |
Love It!
#10 |
BAMF SS
You can't really rate a transmission by power, because it differs from car to car basis...... for instance a turbo car is going to put a lot less wear and tear on the transmission, at the dragstrip, than say a nitrous car
or a heavier car is going to be a lot more stress on the transmission than a lighter car. That is the main reason why guys with 08+ c6 vettes have no problem with their tr6060's, but we are breaking the output shafts left and right. Which leads to the output shaft issue. As mentioned before, there is no support bearing on the shaft, which allows a lot of deflection. To remedy this you can either install a support bearing (i know rpm transmissions does this) or make the shaft stronger (driveshaft shop is working on this), or if you got the dough, do both (rpm offers this in their "built" transmissions). Then there is of course the syncros and keys and shift forks.... all of those should be upgraded, if you have it apart, but that goes with any manual transmission.
#11 |
Thanks for your input. I'm only about 15 mins from D&D so I will talk with them when they return after the holiday.
#12 | |
![]() Drives: SW 2SS/RS Join Date: Apr 2010
#13 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
We finally finished the package which includes a new 4340 main shaft, new output shaft, new synchro kit, and machined housing to accept new larger Viper shaft bearings and additional rear bearings. Even finished the first install and worked perfectly. PM me if you're interested!
#14 |
I wasn't! Was going from 1st to 2nd kinda grinded the gears going into 2nd. On the way home is when the jumping out of 6th started......
| Best GMPP upgrades, if any at all? | Muzik36 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-06-2011 07:32 PM |
| Insurance after performance upgrades | bwpaint | 5th Gen Camaro SS LS LT General Discussions | 15 | 11-23-2010 07:31 AM |
| V8 Tranmission Upgrades | Dreamer2430 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 06-03-2010 07:50 AM |
| What upgrades are you guys doing and in what order? | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 41 | 09-29-2009 05:45 PM |
| Getting Started on Cobalt Upgrades Question | stovt001 | General Automotive + Other Cars Discussion | 11 | 07-24-2009 11:20 PM |
