Old 03-19-2010, 10:56 AM   #1
Bowtie Junkman
Bowtie Junkman's Avatar
Drives: 2000 Camaro SS
K&N (or any) CAI install question ...
I am getting my K&N Aircharger CAI from OCD Customs today and plan on installing over the weekend ...
Question ... is it necessary to pull the negative battery cable? I don't mind resetting the clock/radio/functions, but I'm worried about the window indexing ...
Thanks for your input ....
Bowtie Junkman is offline   Reply With Quote
Old 03-19-2010, 11:30 AM   #2
hair10
hair10's Avatar
Drives: 2SS - Transformer Edition
I installed my CAI, Inc. intake and didn't pull any battery cables. If you're concerned that disconnecting the MAF and reconnecting after install is going to cause problems, it didn't on mine.
There are 542,000 children in foster care. Talk to your local foster and adoptive agency. You could change a life.
hair10 is offline   Reply With Quote
Old 03-19-2010, 11:33 AM   #3
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I did this same install, same CAI. I would strongly suggest that you do remove the cable for safty as well as computer issues. The window index can be a pain in the a$$. It took me several tries to re-index.
Good luck.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 03-19-2010, 01:11 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Good luck.
What safety or PCM issues were you concerned about?
The only thing that is electical is the MAF plug. Unplugging it is no issue at all. Do the K&N instructions tell you to unhook the battery?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-19-2010, 04:18 PM   #5
Bowtie Junkman
Yes, K&N instructions tell you to disconnect the negative terminal ...
Old 03-19-2010, 08:31 PM   #6
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I did mine, I don't really know why. Guessing, its probably a safety disclaimer, K&N might be liable if some douche hit the starter while another was changing the CAI.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 03-19-2010, 09:01 PM   #7
MyIBMssRS
Drives: 10 IBM SS RS/14 1500 Z71
I installed the Halltech intake today and didn't unplug the battery. Only took about 15-20 minutes to complete the install.
MyIBMssRS is offline   Reply With Quote
Old 03-19-2010, 09:37 PM   #8
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
i don't think you need to disconnect the battery as the computer learns the new airflow by itself.
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 03-19-2010, 10:05 PM   #9
GeorgeM
Drives: 2016 2SS, Yellowjacket, A8
When I installed my Airraid CAI I disconnected the negative battery and pulled the #5 and #15 fuses. I don't know if this makes any difference in recalibrating the computer on the LS3, but I did it anyhow.
However (helpful bit of advice), when you disconnect the battery cable DON'T shut your trunk. There is no way of opening it (with battery disconnect) other than climbing through the backseat and pulling the emergency lever inside the trunk well.
Also, when you disconnect don't try shutting your doors, you could crack the windows. They stay up until the battery is reconnected and indexed by the computer.
GeorgeM
GeorgeM is offline   Reply With Quote
Old 03-20-2010, 04:17 AM   #10
Big Brunsy
Drives: 2010 supercharged LS3
I also bought the K&N intake, was gonna install it myself, but the guy doing my muffler delete said he'd install it for $25 if i brought it in at the same time as the muffler delete/x-pipe install.....for $25 I'll let him do it
Big Brunsy is offline   Reply With Quote
Old 03-20-2010, 04:35 PM   #11
axis
Search Ninja
axis's Avatar
That comes to $75-$100/hr since it only takes around 15-20min to do it, lol.
Halltech CF 102 fed
Old 03-21-2010, 10:38 AM   #12
TacoMike82
TacoMike82's Avatar
Drives: 2010 CGM 2SS/RS 6Spd
I unplugged mine, and, to my surprise, the car kept all the radio settings. Only thing that I had to fix was the date/time and the window indexing which took about 90 seconds. The only reason I did it was becuase the instructions said to. I didn't know the computer would automatically relearn the new intake though, that is pretty cool.
2010 2SS/RS CGM, 6Spd, K&N Aircharger, Lloyd's
TacoMike82 is offline   Reply With Quote
Old 04-03-2010, 07:56 PM   #13
Nate33
Drives: 10 Camaro RS 2LT, 11 Avalanche z71
problems after K&N installation?
Anyone have issues with car starting after installing K&N intake for v6? Car starts up for 2 seconds and shuts right off. Emissions sensor maybe or some anti-theft crp?
Nate33 is offline   Reply With Quote
Old 04-03-2010, 08:17 PM   #14
axis
Search Ninja
axis's Avatar
Did you plug the MAF back in? Go over everything and make sure it's all plugged in properly. Unplug and plug it back in too. Sometimes things don't make a tight connection. If worse comes to worse, take it out and put the stock setup back in to eliminate that as the issue. I don't see how this could happen unless you didn't plug the maf back in but it's a place to start.
Halltech CF 102 fed
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Warranty Question for Headers, CAI, and Tune Inferno2SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 08-16-2010 02:10 AM
HELP! Fuel malfunction code after CAI install scomaro22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 01-17-2010 06:19 AM
SLP side gills...Install question newagemuscle Cosmetics and Lighting Modification Discussions 2 12-26-2009 02:44 PM
CAI question Chrisrp454 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 10-02-2009 09:15 AM
