Old 01-20-2011, 04:22 PM   #1
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Fluid change at dealer?
Since I'm trying to keep documents of all my oil changes and services in case something goes wrong and I need to prove proper maintenance, I have a question.
I am planning on changing all my fluid before C5fest, but doing at the dealer would probably be more expensive than the local jiffy lube etc.
As long as I get a receipt of the service, do you think there will be a problem in case something happens?
I know it seems paranoid, but I always like to be on the safe side.
Old 01-20-2011, 04:24 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
Some people are paranoid but unless the dealership is doing free oil changes I would not take it to them and they CAN NOT require it for warranty.
I do my own oil changes and I keep my recepits, date/time stamps and mileage info for when it was changed.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 01-20-2011, 04:25 PM   #3
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
You're right, I've never seen it happen first hand, but I've heard of it happening with other car companies. Ask GTAHVIT about what happened with his Mazda.
And I live in an apartment, I have nowhere to do it, myself.
Old 01-20-2011, 04:51 PM   #4
jtzako
Just keep receipts and a log book of all oil changes like I mentioned regardless if it was done at a dealer, jiffylube or by yourself. If you ever did have trouble and they wanted to try and deny warranty they wouldnt have any legal grounds to do so.
FWIW, I've seen the aftermath of quick oil change stores and I just wont use them anymore.
They do not drain all the old oil out of the car. (it takes more than 5 minutes for it all to drain.. even upwards of 20 minutes to really get it all out of there)
They also over tighten oil drain plugs (and filters) and in many cases people find out they dont have the proper amount of oil in the car.
Im not saying a dealership cant make the same mistakes, but at least dealership people are trained by the mfg to do what they do rather than some kid who needs a part time job.
Old 01-20-2011, 04:52 PM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
True, either option has it's pros and cons.
I'll do some research on prices.
Old 01-20-2011, 08:33 PM   #6
Amenti
Amenti's Avatar
Drives: 2017 1SS Convertible
I will never trust a Jiffy Lube to touch any car of mine again. I used to have an old beater of a Pontiac Grand Am and I took it to Jiffy Lube for fluid changes three consecutive times.
All three times, they left my power steering fluid cap loose and all of my power steering fluid bubble out of the reservoir on the drive home and created a hellacious mess. Two of the three times, I found the engine and transmission dipsticks loose.
Just don't even do it, and shame on me for waiting til the third time to swear them off for life.
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties
Coming Soon: BMR Trailing Arms
Amenti is offline   Reply With Quote
Old 01-20-2011, 08:45 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
Also think about it. If you have to drive to the jiffy lube then your oil is hot and not in the pan. A quick 5 min drain wont get anything out due to the lack of oil in the pan.
Click to view my build thread
Recommed all to do differential fluid change!!! jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 116 07-27-2016 07:08 AM
Change your differential fluid! Shift Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 09-27-2015 08:03 PM
Great dealer experience for a change! gdarrah99 Camaro Price | Ordering | Tracking | Dealers Discussions 13 03-02-2010 08:53 PM
Dealer Change boatingbent 5th Gen Camaro SS LS LT General Discussions 0 05-21-2009 08:34 PM
Ok called my dealer to change my order 2SSRS@Gen5diy Camaro Price | Ordering | Tracking | Dealers Discussions 3 02-27-2009 06:10 PM
