Whipped
Drives: 2010 CAMARO Join Date: Sep 2008
My wife's HHR has a single LED in the roof liner. I like this idea. . . So, I am attempting a DYI.
I got picked up a OEM LED from the doors. ![]() I modified a regular plastic ground effects clip. Added two pieces of double sided tape on each end. I was trying to make the clip the same level as the LED holder. ![]() Temp install. ![]() ![]() ![]() The LED will be shining through one of the stock holes in the console. There's no microphone on the passenger side. On Star / Hands free Microphone. ![]() Diver side where the mic goes. ![]() Installed. ![]() What I wanted to do is purchase another microphone and use it to hold the LED.. . . why I am NOT doing that is because that little mic is $70!!! Still not sure if I like the way the LED is installed. . . I am open for any thoughts.
knows 2 facts about ducks
Looks good. Why not just fashion a holder yourself.
Whipped
I've been considering that. . . but I'm unsure what to make it out of just yet. . .. .5" plexi glass would work well, or I could widdle some wood. LOL
Whipped
Ok, new idea.
Instead of re-inventing the wheel I am going to go with this. I ordered the part that holds the LED in the HHR's. ![]() ![]() If you look at the over head console, there's a square on the driver side. ![]() ![]() This is where i'll be putting the LED light. I picked up a stock LED door light. ![]() It will need some work, but I'll make it fit. ![]() ![]()
Whipped
should have stated I'll be painting that part flat black to blend in.
#6 |
Custom User Title :D
Drives: 2011 Summit White 2LT/RS Join Date: Dec 2009
... the malibu's also have LED's in the overhead console, they're molded a bit differently than the door ABL lights, but same color LED.
#7 |
Hey can you share how you took the overhead console out?
#8 |
Auto body and paint guy
Drives: 2010 Camaro LS Join Date: Feb 2011
i have a extra dome light assembly i can sell.. it has everything and the little mic.. send me a message if ya want.. or do a search of threads i made.. i have a for sale thread with pics of it..
#9 |
Whipped
Update:
To take the unit out, you need to push the clips in. ![]() Then the two screws found at the black "L" brackets. ![]() I cut back the plastic on the LED. ![]() Made a holder out of a chunk of plexi glass. ![]() ![]() ![]() I painted it black. ![]() Then I hot glued it in place. ![]()
#10 |
![]() Drives: 2010 Camaro LS Join Date: Jun 2010
#11 |
Whipped
If this doesn't have the look I want, I'll use the holder from the HHR I bought.
#12 |
Whipped
Think it turned out looking great.
![]() Don't pay attention to the wire in the back ground.. I still need to fine tune the setup and hide the wire.
#13 |
it might be hard, but can you try and capture the glow on the center console from the LED ?
#14 |
Whipped
i would if I had a center console in my car. . LOL... in the middle of adding HUD, thus taking out the dash.
| Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! | Wes@Flashtech | Exterior Parts & Accessories | 51 | 09-27-2010 08:19 PM |
| Dome light blinks with left turn signal | ssdavidw | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 20 | 08-10-2010 03:16 PM |
| Dome light help | OrangeCruSSh | 5th Gen Camaro SS LS LT General Discussions | 11 | 08-06-2009 08:14 PM |
