![]() Drives: Chevrolet Camaro 1LT 2010 V6 A6 Join Date: Aug 2010
Normal coolant temperature
What is normal coolant temperature for normal and low rpm driving?
Outside temperature around 32F. Coolant temperature 203F while driving under 3k rpm. 207F while idle. Are these normal? |
376 cubic inches of fun
My coolant stays around 190F, regardless of weather conditions, when driving "normally".
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
That's normal. V6s have a different thermostat than the V8s and run hotter. They also seem to like it hotter (engine temp, not air). Worry if you start getting above 210 while driving.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
Ok.
Thanks |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
190 For the LS3 with stock thermostat and 176 with the 160 thermostat for average driving on the freeway.
#6 |
Does LS3 thermostat fit to LLT?
Im not mechanic so I probably wont change it. But just asking. |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 09:57 PM |
| LS3 Coolant Temperature Fault | Isshinryu | Tuning / Diagnostics -- engine and transmission | 3 | 09-11-2010 11:26 AM |
| Normal coolant temp? | SirZoltan | 5th Gen Camaro SS LS LT General Discussions | 4 | 03-07-2010 08:34 PM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 10:03 PM |
| Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 04:42 PM |
