Old 02-06-2011, 01:22 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
What's your ride height for autocrossing?
Well, I've finished my Pfadt coilover conversion and am waiting for things to clear up to go for corner balancing and a first alignment.
So, I'm wondering what other fellow autocrossers who are lowered have experienced with their Camaros wrt the ride height. Has anyone played around with their car's ride height to see if lower is faster or what the optimum height would be?
Thanks!
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 02-06-2011, 06:29 PM   #2
600hp-lpe
Drives: 2010
what tires/wheels are you using?
I use a 25.6" tall 18" A6 Hoosier tire.. they dropped the car a lot.
Suspension is down 1".
I just clear with my 19's on the car to be able to align the car.It gices me a 1/4" clearance on a hunter alignment machine when in place.
I can't align or load the car in the trailer with the 18's as they drop the car too much.. I had to modify the lower control arms so they would clear when at the apex of the corner. Can't go any lower with the 18's I use.
BTW.. tire sizes for the tires I ruin are in my signature.
600hp-lpe is offline   Reply With Quote
Adjustable sway bar setting for daily driver? JProberts Suspension / Brakes / Chassis 128 12-02-2010 12:19 AM
Measure your car's height alfie43 5th Gen Camaro SS LS LT General Discussions 8 10-07-2010 11:56 AM
Height Adjustable Coilovers? Shurenuff Camaro ZL1 Forum - ZL1 Specific Topics 13 07-31-2010 11:07 PM
concered about my height w/ sunroof Rocky918 5th Gen Camaro SS LS LT General Discussions 15 08-24-2009 10:41 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 01:14 AM
