Smokin Bowties Member
Drives: 2010 Camaro 1LT/RS Join Date: Mar 2010
Wiring 2 subs in seperate boxes parallel
I currently have two seperate speaker boxes each with a single 12" subwoofer both running on a 1 channel mono amp. My question is how do I wire the boxes together in parallel? Do I need two sets of speaker wire terminals on one box, so I run from amp to terminal 1 on the outside of box which connects to the sub, then another wire from the same sub to the second terminal. Then the second box is connected "thru" the first one?...............Or do I have both the output from the amp and the wires for the second sub box twisted together and stuck into a single set of terminals on the first subwoofer? Please keep in mind I have 2 seperate sub boxes and I need them to be wired in parallel only and I cannot change this configuration. Thank you for any intelligent replies in advance, I know there is a guru out there somewhere.
/////Alpine
Drives: Alpine Perfect F.I.T. Camaro Join Date: Sep 2010
Simple way - Run both sets of wires from the boxes back to the amp, put both positives in the amps positive and both negatives in the negative side.
Other way - run +/- from the amp to +/- of the 1st sub. Connect the subwoofer #1 to these wires and also connect the +/- wires you want to run to the other subwoofer to these terminals too (either a terminal plate or the speaker terminals on the woofer). Run these wires to the +/- of the other subwoofer. In the end, you want to make sure you have a that all positive terminals are connected to the + of the amp and all negatives are negative .. whether you daisy chain or direct wire each one is up to you. Jim |
#3 | |
SoCal Family Member
Black on Black, how are you hooking the amp? I have the same kind of set up but with 10in subs. I am going to install this weekend. Thanks.
#5 | |
#6 | |
SoCal Family Member
#7 |
Unfortunately no not that I know of...that is the reason the pac is needed
#8 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
http://www.bcae1.com/spkrmlti.htm
take a look at the series parallel diagram in that link, that should help explain it all
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
#9 | |
http://www.camaro5.com/forums/showthread.php?t=67472
#10 |
And this one
http://www.camaro5.com/forums/showthread.php?t=41042
| need the 3 fuse boxes wiring diagram | sinergy camaro spain | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 4 | 09-17-2010 05:26 AM |
| Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) | TAG UR IT | USA - Texas | 41 | 10-19-2009 08:56 PM |
