Old 03-02-2011, 04:09 PM   #1
blake-b
blake-b's Avatar
Drives: 2009 ZR1
For the love of God, how do I get the fuel line disconnect tool to work??
My God, this is becoming personal. I pushed, pulled, twisted and done combos of each and that little light blue POS isn't doing its job.
Any tips?
Old 03-02-2011, 04:12 PM   #2
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
Press the 2 lines together, then place the tool inline and as you slide it under the lip twist it to ensure to release all the retainers within the connector.
Keep the continuous pressure of the two lines together until you have done the above then they will pull apart easily.
Pat
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 03-02-2011, 04:19 PM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Pat
I have no idea what I am doing wrong. I even had my son help. I focused on squeezing the parts together and all he had to do was pull on the line. Still can't get it...
Old 03-02-2011, 04:22 PM   #4
freemaSSon
freemaSSon's Avatar
My immediate guess is one of the flat metal retainers inside the female end is damaged and causing you this head ache. Wish I were there. 15 seconds. Sorry brother.
author unknown
Smokey Yunick
Old 03-02-2011, 04:24 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
How do I get around it if it is damaged?
Old 03-02-2011, 04:25 PM   #6
freemaSSon
freemaSSon's Avatar
The trick is you HAVE to release the pressure of the inside retainers inside the female end from being in contact with the flar on the male end. REALY get aggressive with pressing the two lines together before trying to release the ratiner flaps in the female end.
author unknown
Smokey Yunick
Old 03-02-2011, 04:29 PM   #7
freemaSSon
freemaSSon's Avatar
It will come off even it the tips are slightly damaged. it is all in the retainers being in contact with the flar. Also get really aggressive with the tool when trying to release the retainers.
Flying right now or I could post a picture of the inside of the line so that you could see exactly what you're trying to release which could aid you in understanding the issue that is stopping you.
author unknown
Smokey Yunick
Old 03-02-2011, 04:40 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Still no luck, I even used the open end of a wrench around the line to give me more grip purchase...
I'm beginning to think a hacksaw is in order and I'll buy a new one... have to check prices first...
Old 03-02-2011, 04:56 PM   #9
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Did you get the gas out of the line, pressure in the line will not let you press the 2 lines in.
Old 03-02-2011, 05:01 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Um no... I can push the lines in, they just won't part. How do I release the fuel pressure? The battery is undone, the front of the engine is apart... I am doing a cam and heads and am stuck at this part...
OK, I found the pressure release at the end of the rail....
Old 03-02-2011, 05:09 PM   #11
2SSRS@Gen5diy
What heads?
Old 03-02-2011, 05:10 PM   #12
blake-b
blake-b's Avatar
Drives: 2009 ZR1
What heads?
WCCH Stage 2
Old 03-02-2011, 05:31 PM   #13
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
As best I remember the fuel line uses the 3/8 inch release tool.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 03-02-2011, 05:36 PM   #14
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I am using the tool. It just won't come apart. I released the fuel pressure and have tried all combinations of pushing, pulling, and twisting.
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
HELP! Fuel line nut rusted, can't remove fuel filter theholycow General Automotive + Other Cars Discussion 48 07-27-2009 01:20 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
