Old 03-07-2011, 03:55 PM   #1
footballtick
footballtick's Avatar
Drives: 2011 2SS Cyber Gray
Question about tap shifting when trans in 'D' mode.
218 miles on my new Camaro... so this may be a n00b question.
I have found that if I accidentally hit a tap shift button on the steering wheel, while the transmission is in 'D' the transmission will jump into manual mode.
After this occurs - which can be unsettling because its unexpected - I can use the tap shift buttons to change gears. To get it back into 'D' mode, I have to move the transmission lever into "M", then back into "D" and the trans went back into auto mode.
Is this normal?
-AC
footballtick is offline   Reply With Quote
Old 03-07-2011, 03:56 PM   #2
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
Yes.
1BADLS3 is offline   Reply With Quote
Old 03-07-2011, 03:58 PM   #3
liquidsmoke
Two Miles An Hour
Drives: SIM 2LT RS
you can also just hold down the tapshift button and it will go back to S mode
expect nothing, but take everything
liquidsmoke is offline   Reply With Quote
Old 03-07-2011, 04:01 PM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
You have that backwards. If you put the gear shift into "M" you can use the tap shift buttons on the steering wheel to Manually shift gears. If the gear shift is in "D" then pressing either of the tap shift buttons on the steering wheel will do nothing.
(At least, that's the way it's supposed to work )
My VIN = 2G1FK1EJ9A9105017
Old 03-07-2011, 04:04 PM   #5
CFD
Drives: 2SS/RS L99 BLACK
The 2011's can use tapshift in "D" as well as "M" if you don't shift with the buttons after a few it will return to auto mod own it's own.
CFD is offline   Reply With Quote
Old 03-07-2011, 04:05 PM   #6
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Doesn't work for me, but I'm in a 2010...
OP- bumping a 'paddle' should yield NO RESULT if you are in "D".
If you want to drive in "S" mode rather than "M", all you need to do is pop the shifter up to "D" and back down to the "M" slot. This will actually put you into "S" mode- sport mode, not manual mode. Once the car is in "S" mode, all it takes to go into manual mode is to shift up or down using the paddles.
Confused yet? Just experiment at low speeds. The car won't let you make any unsafe shifts, so just play around with it.
Old 03-07-2011, 04:06 PM   #7
Revo1
Drives: 2010 2SS/RS
I just got educated
Old 03-07-2011, 04:09 PM   #8
CamaroSkooter
Son of a...
Old 03-07-2011, 04:21 PM   #9
footballtick
Ok. The behavior is confirmed to be normal.... But it is unexpected, no?
I was doing a u-turn and smacked a tap shift button (down) and the damn
thing went into a gear and stayed there. When I accelerated I thought the car was
going to explode. Scared the octane out of me.
Old 03-07-2011, 04:24 PM   #10
Lumix
Lumix's Avatar
Drives: 2015 1LT
...only if you have a V8. The 2011's with V6 won't tap shift in "D" mode...
Lumix is offline   Reply With Quote
Old 03-07-2011, 04:48 PM   #11
Ghost Rider
I'm one bad Mamma Jamma
Ghost Rider's Avatar
Drives: 2010 Camaro SS/RS
I didn't know 2011s would do that. I really wouldn't want paddle shifting in D mode. Too much opportunity to accidentally hit the paddles as happened in this case.
I dare you to challenge my BRUTE!
http://ghost-rider-5.mybrute.com
DELIVERED on August 25, 2009- 2010 2SS/RS, Yellow, A6, VIN # 34902
DELIVERED on September 9, 2009 -Custom Bumblebee Stripes and engine cover.
DELIVERED on September 10, 2009 - Painted GFX
Ghost Rider is offline   Reply With Quote
Old 03-07-2011, 05:11 PM   #12
CFD
I've been educated as well.
Old 03-07-2011, 05:11 PM   #13
CFD
I agree, don't no why they added this feature.
Old 03-07-2011, 05:13 PM   #14
CamaroSkooter
I would like it. I'm always down-shifting when coming down hills then shifting M-D-M to get back into "Sport" mode so I don't have to remember to shift
tap shift
Question about Auto Shifting Rocky918 5th Gen Camaro SS LS LT General Discussions 20 08-01-2009 08:46 AM
Competition Mode Question CJ Offshoredude 5th Gen Camaro SS LS LT General Discussions 2 07-16-2009 08:30 PM
Manual mode question swoopusa 5th Gen Camaro SS LS LT General Discussions 1 07-12-2009 12:32 AM
Question about changing out my Trans Am's computer Lee9710 General Automotive + Other Cars Discussion 0 04-29-2009 07:01 AM
I have a question about 4th gen trans am mike302 4th Generation Camaros 6 04-17-2009 05:23 PM
