Old 03-11-2011, 05:56 PM   #1
mekc57
IOM inside and out
mekc57's Avatar
Drives: 2SS/RS 2010 Camaro
Got an L99 question Manual mode
I've got a year old L99 and I have noticed, from day one, that it smells hot after driving it in manual "tap shift" mode. Not all that hard, just normal "like a standard" I don't notice it while driving and the gauges don't show any more heat. I smell it when I get out. Almost like slipping fan belt, maybe a little oily when I've been driving it like a stick.
Might this be because I need a catch can? Like in manual mode I'm pushing a little more oil into the intake?
I haven't seen any oil leaks, no spots in the garage were I park and I don't notice it when I drive it in auto mode, no mater how hard I drive it!
Thanks
mekc57 is offline   Reply With Quote
Old 03-11-2011, 06:14 PM   #2
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE
I thought it was just me...........
Thanks
Mine does the exact same thing. I sure hope someone has an answer!
GMteSSted is offline   Reply With Quote
Old 03-11-2011, 06:21 PM   #3
mekc57
IOM inside and out
mekc57's Avatar
Yeah, I'm thinking it might be building pressure in the crankcase under deceleration and pushing oil through the stock PCV valve into the intake.
Like you said, thought it was just me! Haven't seen anything on here about it yet so thought I would bring it up and see if anyone had an answer for us
Old 03-11-2011, 07:23 PM   #4
Justice
Justice's Avatar
Drives: 2016 Hyper Blue 2SS
I notice the same thing. Mine is brand new and I just had exhaust put on. I thought it was maybe that breaking in, but I do drive it in M mode to avoid the AFM as much as I can. I haven't talked myself into getting it tuned out yet. But yes I notice the same smell after driving.
Justice is offline   Reply With Quote
Old 03-11-2011, 08:17 PM   #5
mekc57
IOM inside and out
mekc57's Avatar
I hope someone will give us an answer on this!!!
Old 03-11-2011, 10:35 PM   #6
USNSCPO
Gearhead
USNSCPO's Avatar
Drives: 2010 2SS/RS L99
Haven't noticed this, but will watch for it.
Might this be more related to the brand/type of OEM trans fluid or it being slightly low? It would be interesting to know if anyone who's changed to Amsoil or Royal Purple has observed this behavior?
The oil theory doesn't make sense to me because any oil passing through the PVC system is immediately ingested and burned in the engine. Its supposed to be a sealed system, so there really isn't a way for it to vent. I suppose oil vapor could migrate up into the valve covers and leak out around the oil fill cap? Anyway, I'm no expert, just speculating so perhaps an expert can suggest or figure out the cause.
USNSCPO is offline   Reply With Quote
Old 03-11-2011, 10:38 PM   #7
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
I'm reposting my comments from another thread that you may be interested in:
"Just got the car back from the dealer and they did the lifter swap but it was still smoking on cold start. Dealer discovered another reported issue ( no TSB though apparently ) regarding an updated Valve Rocker arm Cover - Left Side- part # 12570427 and PCV tube- part # 12617239. Perhaps this would explain why so many are installing Oil Catch cans ! These new parts are on order. "
The new/updated Rocker arm cover is actually the LS3 cover I believe. There is a different baffle plate inside to help reduce/prevent oil from being sucked into the PCV pipe and into the intake. The is still no TSB on this issue but there is a PI #0104B - Excessive oil consumption........
This could explain why under agressive driving there could be oil being sucked into the pcv pipe and subsequently the intake.
TAPSHIFT is offline   Reply With Quote
Old 03-11-2011, 11:15 PM   #8
mekc57
IOM inside and out
mekc57's Avatar
NO, there is no leak!!!!
It just smells hot when you drive the auto in manual mode.
My point was that it might be from the motor burning the oil that was being passed through to the intake. I have worked on cars all my life, am now in my 50's, I do my own oil changes and it's not a leak, It's more of a smell. Hot or burning rubber type smell in the engine compartment after driving with the tap shifters and not even getting on it, Just normal driving
Old 03-11-2011, 11:17 PM   #9
mekc57
IOM inside and out
mekc57's Avatar
This might be what it is!!! Maybe they didn't think we would down shift the auto like you do in the standerd.
Thanks for the input!!!!
Old 03-12-2011, 11:45 AM   #10
GMteSSted
GMteSSted's Avatar
OK, at least three of of us have this issue?
Have you folks checked your oil level? I know mine is not losing any on the dipstick. I do change it annually and put less than 3k on the car last year.
If we are burning it shouldn't we be low on oil, at least some?
Old 03-12-2011, 11:55 AM   #11
CFD
Drives: 2SS/RS L99 BLACK
I have never noticed this myself and I think most of you know I use tapshift exclusively and drive my car agressively.
CFD is offline   Reply With Quote
Old 03-12-2011, 01:00 PM   #12
erk5000
Drives: 2010 Camaro 2SS L99 SIM
Same here... I have not noticed this issue and I use CFD's tap shifter.
erk5000 is offline   Reply With Quote
Old 03-12-2011, 01:24 PM   #13
mekc57
IOM inside and out
mekc57's Avatar
OK, I guess that rules out the valve cover design on the L99.
I'll have to go out and do some spirited tap shift driving and then do a good underhood inspection and see if I can find anything that might be the cause. I don't really want to put a catch can on just to find out if that might be the cause. I know the dealer is just going to say," Funny, I don't smell anything" like the sales man did when I bought it.
I have used just a touch of oil since my last change but it's been almost 4000 mi and it was down mabe 2 cups. Nothing to show a problem there.
Old 03-12-2011, 04:03 PM   #14
mekc57
IOM inside and out
mekc57's Avatar
Maybe it's a belt tesioner issue. It doesn't squeel or anything but it might be slipping a little under higher RPM's
Question about tap shifting when trans in 'D' mode. footballtick 5th Gen Camaro SS LS LT General Discussions 27 03-11-2011 06:49 PM
L99 launch, no one using comp mode? general23cmp Dragstrip and Launch Techniques Discussion 81 11-16-2010 07:45 PM
L99 Tapshift in drive mode 2011??? Brettscamaro Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 09-23-2010 10:14 AM
Question about Manual cover Red Jewel Dan 5th Gen Camaro SS LS LT General Discussions 31 12-09-2009 02:45 PM
L99 A6 guys, tranny question 9c1ny V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 06-27-2009 11:41 PM
