![]() Drives: 1SS Camaro Join Date: Sep 2010
Urgent! Oil Change Help Please
I've just got done draining my vehicle and changed the oil for the fourth time... but this time im freaking out a little bit. When i transfered the old oil into the old oil bottle I noticed I didn't have nearly enough oil in the catcher than I should of.. I only had a little less than four quarts... well I'm guess either the four quarts leaked or im screwed... cause I put eight quarts on top of the four that were still some how in the engine.
Well I freaked and decided I'm going to empty the oil and re do my oil change.. so I take the oil plug off... and nothing came out?...WTF? where the hell is the oil? Is my oil pump shot? is there a clog somewhere? Im baffled and freaking out. Any help asap would be very much appreciated....
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
Born: August 27, 2009
Drives: 10CAMARO SS,12CRUZE RS,07 YAM R6 Join Date: Aug 2009
did you start it up after you added the oil???
Victory Red 2SS/RS
Vin# A9130145 |
yes.. unfortunetely... just for a second
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
How much oil is the dipstick showing.
Are you sure you took off the engine drain plug and not the transmission? |
nothing happened... no pops.. or unusualness...
#6 |
I've made the transmission plug mistake before.. its hard to make that mistake twice... the dipstick reads way too much.. but it wont drain???
#7 |
remove the filler cap??? maybe a vaccum situation???
Victory Red 2SS/RS
Vin# A9130145 |
#8 |
stick a small screwdriver in the hole, must be something there blocking it from draining.
#9 |
Drives: 2011 2SS Join Date: Jun 2010
Dude. The dipstick goes right into the oil pan where your plug is at. Make sure you are removing the oil pan drain plug and remove the oil fill cap.
#10 |
it's a space station!
Try taking off the oil fill cap, it might be creating a vacuum. I'm sure you thought of this but just throwing it out there.
Edit: I see others posted the same thing as I was typing.
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 ss camaro Join Date: Aug 2010
this outta be good.
10/28/2010 got it
#12 |
#13 |
The engine is vented through the pcv, there isn't that much vacuum that would be holding oil up. I've drained thousands of engines without taking the cap off. Something must be blocking the drain hole. Poke a screwdriver in there and see what pops out.
Assuming your taking the right plug out and didn't actually drain the transmission. |
#14 |
wow.. yall can be mean, as I am to be known as the guy that drained my tranny fluid..twice... maybe I should start letting the pros change my oil. I can install a CAI, borla exhaust, but I cant seem to drain the right fluid. Thanks for your help.. hopefully I didnt' mess up my engine by starting the car with 16 qaurts of oil in the car. FML
| DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 07:11 PM |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 09:51 AM |
| A NEW generation of oil, for ALL GM cars | Sir Nuke | 5th Gen Camaro SS LS LT General Discussions | 48 | 11-03-2010 10:33 PM |
| Anyone notice oil residue everyone oil change? | speeD3m0n2010 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 6 | 09-23-2010 08:22 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 10:47 AM |
