Old 03-13-2011, 09:49 PM   #1
texcraig
texcraig's Avatar
Drives: 2011 2LT RS White/Orng Strip
A/C Freeze Up
Anyone have a problem with the A/C evaporater freezing up. We drove a few hrs with the A/C on, low fan. Noticed not much air blowing so I figured it was iced. I turned of the A/C with the button/switch but the compresssor was still turning when I checked under the hood. It would not shut off no matter what button I pushed. I shut off the engine, waited a while, restarted, then ice was coming out of the vents. Today driving the same for a few hrs no problem. Compressor turns off and on when I use the a/c button/switch now. ??? maybe a sensor??
Ant ideas anyone.
texcraig is offline   Reply With Quote
Old 03-17-2011, 03:36 PM   #2
Rick@Metco
Drives: 2010 Camaro RS/SS
There's a TSB for this...A software update should fix the problem. See your dealer.
2010 Camaro RS/SS
2009 Challenger SRT8
1986 Monte Carlo SS (GN-Powered)
1984 Monte Carlo SS (Rat-Powered)
Rick@Metco is offline   Reply With Quote
Old 03-17-2011, 11:47 PM   #3
texcraig
texcraig's Avatar
Thanks Rick, I will check with the dealer.
a/c issues anyone have this? joes407 5th Gen Camaro SS LS LT General Discussions 17 08-06-2020 05:19 PM
Where is the A/C supposed to drain on the ground? 2010 Bumblebee 5th Gen Camaro SS LS LT General Discussions 34 04-23-2014 08:50 PM
Anyone else with A/C problems this summer? O2BQIK Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 08-01-2010 10:07 PM
A/C turned hot, and the engine temp rose Bonemaro 5th Gen Camaro SS LS LT General Discussions 17 07-20-2010 09:04 PM
Odor from A/C vents anyone? OBSSEST Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 10-02-2009 10:39 AM
