Old 03-21-2011, 04:53 PM   #1
bmorecam
recommended floor jack point damaged?
Today I used a floor jack to lift up the front of my car using the recommended positions on the pic and it left a nice dent on the crossmember and possibly a little bend from it. Is this expected or do I have a serious problem on my hands? I used the 2nd crossmember spot from the front of the vehicle on the pic.
Old 03-21-2011, 05:07 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I don't see how you could possibly have bent it... taking paint off.. yup if you didn't put a pad between your jack and the cross-member...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-21-2011, 05:15 PM   #3
bmorecam
I didnt put a pad betweent the jack and the crossmember.. so is the dent ok or is it something that I should be worried about? Maybe is not really bent but it just look like it from the dent but possibly it could be.
Old 03-21-2011, 05:28 PM   #4
MillerTime
MillerTime's Avatar
I'd say your fine, it's probably fine and the scratch is throwing you off.. Only you really know for sure though... The scratch is fine, although I'd grab some closs black paint and cover it over to prevent rust.
Next time use a microfiber rag or towel to prevent the scratches
2G1FS1EWXD9163847
Old 03-21-2011, 05:38 PM   #5
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
They also sell rubber spacers that are specifically made for floor jacks. They double as beer coasters.....
wrbear is offline   Reply With Quote
Old 03-21-2011, 05:48 PM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
That can't be right.....only one floor jack up front?
How are you supposed to keep it from wobbling? (Yes, I realize both of the rear tires are on the ground still....but it's not going to be what I'd call "stable"....is it?
Old 03-21-2011, 05:48 PM   #7
outlaw2
outlaw2's Avatar
Drives: 12 SS/RS Conv, 66 Impala SS Conv
Been there,done that also had a thin rubber pad but the car sat so low and still bent the frame foward of engine as photo shows. This is a heavy car and the frames are not like old Chevys 64-70 "HEAVY METAL" At least my first Dent is on the under side instead of the fender or door and at least I did it not someone else.
outlaw2 is offline   Reply With Quote
Old 03-21-2011, 05:51 PM   #8
C5RocksC5
Banned
C5RocksC5's Avatar
Drives: 2010 Camaro 2SS/RS
ok, I am with you OP. I did the same thing. The pad on my jack has a raised and grooved edge and I didn't use a flat whatever in between the pad and the cross-member. The result.....slightly bent and scratched crossmember.
C5RocksC5 is offline   Reply With Quote
Old 03-21-2011, 06:18 PM   #9
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Don't use the second crossmember in the front use the first crossmember only.
Old 03-21-2011, 06:32 PM   #10
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Why? more stability or is it stronger?
ackeight is offline   Reply With Quote
Old 03-21-2011, 06:33 PM   #11
bmorecam
so I am ok right? Is not like if I was to have bent the frame or something big like that right? I was just following the picture and recommended positions but I did not think of a pad to put between the jack and the metal. I know now.
Old 03-21-2011, 07:20 PM   #12
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
It says floor jack positions. He didnt post the second half which has the jack stands positions on it.
CamaroC-17 is offline   Reply With Quote
Old 03-21-2011, 07:25 PM   #13
booenson
Drives: 2010 1SS/RS M6
Aren't you able to these points I've circled in red to jack the front up?
booenson is offline   Reply With Quote
Old 03-21-2011, 07:30 PM   #14
Mr. Wyndham
Thanks for that. I didn't see it.
But still...even with a floor jack...isn't it unstable?
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 09:54 PM
Railcar unload point for Phoenix? FrankN Camaro Price | Ordering | Tracking | Dealers Discussions 3 07-31-2010 07:51 PM
3 Point Brace from BMR! HzMajesty Suspension / Brakes / Chassis 7 06-22-2010 09:34 AM
Damaged on Delivery JSC81 Camaro Price | Ordering | Tracking | Dealers Discussions 30 05-05-2010 08:02 PM
At this point will the R6P code matter nards444 Camaro Price | Ordering | Tracking | Dealers Discussions 32 07-14-2009 09:47 AM
