Old 03-23-2011, 10:11 PM   #1
Eric Baker
Drives: Black/Black 2SS/RS 6M
Bleeding brakes for line lock
I have a question and searching turned up nothing.
I will be installing my SJM line lock soon, and was wondering, since you have to disconnect the line before the ABS module, is there a special bleeding procedure? Is a scan tool needed to get all the air out? I'm surprised nobody has asked this yet, at least not that I can find.
Eric Baker is offline   Reply With Quote
Old 03-23-2011, 10:38 PM   #2
JusticePete
Drives: Camaro Justice
Yes, a scan tool is required to bleed the ABS pump. A GM Tech II or equivalent set to 2010 Corvette will do the job.
Old 03-23-2011, 11:08 PM   #3
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
Whats a scan tool? Where can I get one? How much $?
BUMBLE-B-TUNA is offline   Reply With Quote
Old 03-23-2011, 11:32 PM   #4
JusticePete
Hmmm too much http://www.autobarn.net/xxx3627.html
$4,799 but I am sure they throw in free shipping.
Old 03-23-2011, 11:44 PM   #5
BUMBLE-B-TUNA
Drives: 2010 SS
WTF!!! I guess this ain't for a DIY. There must be a different way of doing it. I've seen others install line locks on here???
Old 03-23-2011, 11:58 PM   #6
JusticePete
Now you know why shop rates are what they are. Equipment is very expenssive and then of course you need to get the updates... I would suggest installing the line lock and then having a Pedders or Chevy or other quality dealer do the final bleed with a Tech II.
Old 03-24-2011, 04:18 AM   #7
BUMBLE-B-TUNA
Drives: 2010 SS
Thanks for the tip!
Old 03-28-2011, 08:44 AM   #8
Fubar
Drives: SW 2SS/RS M6
PITA
Fubar is offline   Reply With Quote
Old 04-02-2011, 09:05 PM   #9
Slowhawk
Drives: 1999 Trans Am
I do it the cheap way. Bleed the brakes, drive it into a sandy parking lot and slamm
the brakes a few times.It pulses the ABS system and blows the air bubbles out.
Go back and bleed again -done. No $5k tool needed.
Slowhawk is offline   Reply With Quote
Old 04-02-2011, 09:20 PM   #10
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
4700 is cheap. I paid 12,000 for the snap-on verus!
Oxtar41 is offline   Reply With Quote
Old 04-03-2011, 09:35 AM   #11
Eric Baker
Hmm Don that's a good idea. If I can't find a scan tool that works, I'll use that method. I'v been putting off the install of the line lock and stainless lines.
Old 04-03-2011, 09:44 AM   #12
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
My god...why would you guys make such a mountain out of a little deal. He is just installing line locks. All of the air is after the brake line block. Just install your line locks and bleed your brakes starting at the one that is furtherest away. takes two people on pumping the brakes and one working the bleeder or a vacuum system. as long as you dont run your resevour dry you wont get air in the system before the abs box. You are going to love your new locks...and tire companies will love you...roflmao
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 04-05-2011, 05:08 PM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
Come on man, stay positive
Click to view my build thread
Old 04-10-2011, 10:02 PM   #14
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
HMMMMMM
Fishdadddy is offline   Reply With Quote
Brakes Lock Up after washing the Car bono83 Suspension / Brakes / Chassis 26 05-03-2011 08:07 AM
ABS + bleeding brakes = ? booenson Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 11-13-2010 06:50 PM
Bleeding Camaro Brakes Merc Suspension / Brakes / Chassis 3 09-09-2010 12:30 PM
Bleeding Brakes flyby Suspension / Brakes / Chassis 9 04-06-2010 10:26 PM
Bleeding Brakes flyby Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 04-03-2010 08:40 AM
