Old 03-30-2011, 12:06 AM   #1
Kman 2011 ss
Kman 2011 ss's Avatar
Drives: '04vette- '11-1SS '11-1LS(wifes)
Fuse pull for low octane fuel fix
Ok I have read the sticky on the low octane fuel fix for the L99 (pull #5 & 20 15 amp fuses) actually i'm only on page 18 out of 53 pages but I digress...
My question is this, that thread was started in Aug of 2009, is this still an issue or has GM corrected this problem now that we're in 2011?
1. Do I still need to be concerned if the dealer put in 87 for that first tank of gas? (which I'm only halfway through)
2. From what I've read in the sticky the fuse pull is only a temporary fix. By temproary do we mean it reverts on its own? (if so after how long?) or only if 87 is mistakenly used again?
3. A tune will correct the problem completely? (even if 87 is mistakenly used?)
4. would the fuse pull smooth out the AFM? I know its suppose to be unnoticable but I can feel the difference.
A 2 year old problem should be corrected in the 2011 models, yes?
Thanks for your time.
Magnaflow catback - CAI - Foose Legend rims
Kman 2011 ss is offline   Reply With Quote
Old 03-30-2011, 12:17 AM   #2
Devon
Highway Man
Devon's Avatar
Drives: '10 2SS/RS
Good questions Kman. I was actually about to make a thread asking some of these questions myself, as I'm still not clear on what the deal is after skimming that thread earlier.
Devon is offline   Reply With Quote
Old 03-30-2011, 12:24 AM   #3
Sin
Sin's Avatar
Drives: DEAD
1) It is still an issue on all V8's, 2010 and 2011.
2) It won't go back to the low octane table unless you use 87 again.
3) Not sure...I'm sure the low octane thing can be removed...someone will answer for sure.
4) Only a tune can get the AFM off.
Sin is offline   Reply With Quote
Old 03-30-2011, 12:25 AM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Here is the latest info I got concerning the fuse pull.
Bottom line, YES it's still an issue. Or is it a non-issue.
It's the way GM wants it. For whatever reason they want it this way. I'm guessing less warranty needs the more handicapped the car is. 95% of SS owners will never know their car is underperforming. I KNEW. As did some other on here. We got a resolution, but not before we figured it out on our own. In my sig is the GM TSB for the fuse pull. You can go to the dealer, but it's quicker and easier to just do it yourself.
The OP of the thread is all you need ot know. We try to keep it updated with the more pertinant info.
Old 03-30-2011, 12:36 AM   #5
Devon
Highway Man
Devon's Avatar
Drives: '10 2SS/RS
Checking out your linked thread now PQ. Good stuff!
Old 03-30-2011, 03:57 AM   #6
BIG L/2SS
BIG L/2SS's Avatar
Drives: 2011 Camaro SS
I've replaced my fuse block and I still have A check engine light, I think I'm going to try this out in the morning. I'll let you guys know if it works for me.
BIG L/2SS is offline   Reply With Quote
Old 03-30-2011, 04:09 AM   #7
mikeSS
mikeSS's Avatar
Drives: 2015 c7
guessing less warranty needs the more handicapped the car is. 95% of SS owners will never know their car is underperforming. )
wow thats just sad to think about
Old 03-30-2011, 06:21 AM   #8
Scott@Bjorn3D
PQ,
It is not even 95% of the car. Before GM figured out the issue working on my car a V-6 Camaro beat my SS by 3/4 a car length. Do to the wieght of the SS over the V-6 the V-6 is quicker when the V-8 is in low octane table. You have to remember the 0-60 times we recorded where in the high 6 second low 7 second when the V-6 can do 6 second or slightly less.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-30-2011, 09:00 AM   #9
Kman 2011 ss
Thanks I'm going to read the more current info now.
Old 03-30-2011, 09:05 AM   #10
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I did the fuse pull last night just because I ran out all the dealer fuel and had premium in the car. It is very simple to do. Do it once and keep premium in the car and you should never have to do it again.
Pollock is offline   Reply With Quote
Old 03-30-2011, 09:44 AM   #11
Without Remorse
Drives: 2011 2SS/RS RJT Convertible
Is premium put in from the factory? The car has just a tiny bit of gas in it when delivered but I made sure the dealer put in premium. Should I be OK? I'll probably do a pull at some point anyway but curious.
Without Remorse is offline   Reply With Quote
Old 03-30-2011, 10:28 AM   #12
PQ
Booooosted.
PQ's Avatar
Originally Posted by Scott@Bjorn3D View Post
PQ,
It is not even 95% of the cars.
Probably. My PM box blew up with thatnk yous and appologies. LOL
But had you not called me with the idea, GM was only a week behind us. However, the customer has to complain about low acceleration in order for the dealer to mess with it. So, ya, might even be higher than that of unmoded cars.
Fuse Pull - Other GM Vehicles L99SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-19-2010 04:06 PM
Anniversary....... August, 2009.... fuse pull month.......... PQ 5th Gen Camaro SS LS LT General Discussions 41 08-03-2010 06:46 PM
Fuse pull or battery disconnect? wylde1 5th Gen Camaro SS LS LT General Discussions 9 07-06-2010 02:39 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
