Old 03-31-2011, 12:16 AM   #1
DeathbySS
DeathbySS's Avatar
Drives: 2014 Camaro SS Summit White M6
Question Pros and Cons
I have heard there is no need for an aftermarket throttle body on a new camaro, but I have also heard it couldn't hurt. I would like to know what this forum thinks about it or at least give me some insight. Another thing I'm looking for a cam but not sure what size to get or brand for that matter. I was told just to do headers and a full exhaust, getting cams is whole new ballpark as for modifications to the car. Any help would be greatly appreciated.
This is Nucking Futs
DeathbySS is offline   Reply With Quote
Old 03-31-2011, 01:01 AM   #2
C5RocksC5
Banned
C5RocksC5's Avatar
Drives: 2010 Camaro 2SS/RS
you gonne crap on your warranty anyway so why not just put a supercharger on it and stop the guess work?
C5RocksC5 is offline   Reply With Quote
Old 03-31-2011, 02:48 AM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Quite the opposite. The throttle bodies will give you a few extra HP and improve your throttle response and Idle. Downside is you will need to re-tune to adjust for that extra air coming in.
I have a CAI, a MGW short throw and LT's and my dealer has re-built separate parts of my transmission twice with no real issue with my modifications. The warrant stuff is controlled by the dealer when it comes to bolt ons.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-31-2011, 07:50 AM   #4
SC2150
The VMax CNC pattern ported unit is stock looking from the outside with good documented gains and needs no tune.
Old 03-31-2011, 07:59 AM   #5
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
Who sells the VMAx? What more is there to know about it?
2010 Camaro Black with White Stripes, Jannetty Racing Roto-Fab CAI, VMAX Ported Throttle Body, Long Tube Headers, GMPP Axel Back, Emblem Pros Custom "VOODOO" Under hood Bow tie, Chrome Gill Inserts, HUD plate, Sparks Performance White SS front and rear Plate MPD-1 Spoiler
Hired Gun is offline   Reply With Quote
Old 03-31-2011, 08:49 AM   #6
bmorecam
The guy above u
Old 03-31-2011, 09:09 AM   #7
clg_98ta
clg_98ta's Avatar
When you flow more air w/o retuning, you are leaning out the mixture - that's what gives you the power gain. The cars typically run a little rich (as a safety margin) from the factory. If you port or change your throttle body, you should definitely get a dyno with a/f measurements to make sure you're not running lean. Lean is very bad.
Old 03-31-2011, 10:12 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
http://www.camaro5.com/forums/showthread.php?t=112536
http://www.camaro5.com/forums/showthread.php?t=124165
Build Journal
Old 10-03-2011, 02:59 PM   #9
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
So...do you need a tune with a TB or not? Or are you saying you should check, but you SHOULDN'T need one?
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
cams, throttle body
Pros and Cons about dropping on Springs? xpanda305x Suspension / Brakes / Chassis 19 01-07-2011 02:26 PM
2 Piece Driveshaft or 1 piece? Can anyone explain pros and cons and design issues? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 09-16-2010 08:46 PM
Nitrous Kits - Pros and Cons? attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-10-2010 12:37 PM
Pros and cons of abm? iyam_lorne 5th Gen Camaro SS LS LT General Discussions 24 11-03-2009 06:01 PM
Sunroof Option: Yes or No...Pros and Cons DCJ 5th Gen Camaro SS LS LT General Discussions 55 06-24-2009 10:04 AM
