Old 04-05-2011, 09:41 PM   #1
Saltyflats
Drives: 2011 Camaro SS LS3 6 speed.
Oil Change
How many of you guys did the Mobil 1 oil and filter change at home?
Obviously my next questions is how do I clear the codes on the dash?
Please dont tell me not having my oil changed at my scum bag dealership will somehow void my warranty.
Saltyflats is offline   Reply With Quote
Old 04-05-2011, 09:43 PM   #2
Unknown SSRS
Drives: 2011 VR SS/RS
umm... the reset button... duh! lol
Unknown SSRS is offline   Reply With Quote
Old 04-05-2011, 09:46 PM   #3
nards444
nards444's Avatar
Drives: 1SS/RS Black
i do it at home. Cost between 50-60 bucks to do it. Autozone usually has mobil one sales. You clear your dash by resetting it, i beleive by holding it down, otherwise check your manual. But I like to do the oil on my camaro because to me it's not hard I like to do it and it saves the risk of some 18 year old drop out from forgetting to tighten something or put scratches on it. Not to mention with 8qts and filter you are probably looking at close to 100 oil change
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 04-05-2011, 11:06 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
YEP, I do them all teh time.....all three of my cars.....buit EXPECIALLY my camaro.....just ensure you get enough oil.....a lot of people....believe it or not.....have no idea that the V8 takes 8 quarts.
these instructions are in your owners manual starting on page 10-13
I can assume the CODE your talking about is the "A CHANGE ENGINE
OIL SOON" in the DIC....After changing the engine oil, reset
the system:
1. Turn the ignition key to ON/RUN with the engine off.
2. Fully press and release the accelerator pedal three times within five seconds.
If the CHANGE ENGINE OIL SOON message is not on, the system is reset.
If the CHANGE ENGINE OIL SOON message comes on again and stays on for 30 seconds at the next ignition cycle, it did not reset. The system needs to be reset again.
.OR if you are talking anouty in the DIC and it hasn't given you the message above, but still showing a percentage %, go to the menu.....get to the OIL Percentage and then hold down the button on the end of the flasher.....it will ask you are you sure? and push it again and your done. it resets to 100%
Old 04-05-2011, 11:08 PM   #5
MIQ
A Dichotomy
MIQ's Avatar
Drives: 2011 Camaro 1LT
Why is your dealer a scum bag?
2011 Camaro 1LT Auto
Inferno Orange Metallic
Mods--Magnaflow Axle Back, Eibach Pro-Kit, RX Catch Can
MIQ is offline   Reply With Quote
Old 04-05-2011, 11:09 PM   #6
TOMS1SS
Drives: NA
There is a section in the manual that will tell you how to reset the oil life sensor.
TOMS1SS is offline   Reply With Quote
Old 04-05-2011, 11:09 PM   #7
TOMS1SS
Drives: NA
Aren't they all? If you go to a dealer you'd better be armed with one thing.....knowledge.
Old 04-05-2011, 11:27 PM   #8
macc24
macc24's Avatar
Drives: IOM w/racing stripes black matte
I've seen good dealers and bad dealers....they are in it to make a profit. Like you said be armed w/knowledge and a bit of courtesy - that goes both ways. Ultimately they should be looking for your return business, if not then go somewhere else. Fortunately for us there's not much required maintenance required on these cars. Thanks GM!
IOM Black Racing Stripes Current Mods: CAI Intake, Solo Catback Exhaust (thanks to my awesome wife! 10 year anniversary), Solo Hi Flow Cats. Future Mods: Ported Throttle body, Tune (by a player to be named later) Miniature Arc Reactor.
macc24 is offline   Reply With Quote
Old 04-06-2011, 12:17 AM   #9
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
Do it yourself....But...I use Pennzoil full synthetic, since I verified it is Dexos 1 approved. Easiest oil change I ever did. Took 5 minutes and didn't even get dirty.
Bonanza7 is offline   Reply With Quote
Old 04-06-2011, 09:17 AM   #10
stevea
stevea's Avatar
Drives: just a car
I have always changed my own oil, not only is it a cost savings but while you are under there you have time to take a look around and see if anything else is going on.
stevea is offline   Reply With Quote
Old 04-06-2011, 09:24 AM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Did you set your owner's manual on fire?
Rock-It Man is offline   Reply With Quote
Old 04-06-2011, 09:24 AM   #12
RSokie
Proud owner of Litho #195
RSokie's Avatar
Drives: 2011 CGM 2LT/RS
It is so easy to change the oil on these cars anymore I love it.
Old 04-06-2011, 09:34 AM   #13
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
I just may have to start using that instead of "RTFM".
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 04-06-2011, 09:39 AM   #14
Forza
Drives: 2010 Camaro 2LT/RS CGM
the system:
All I did after changing the oil was the DIC reset using the button reset. What is all that other stuff you listed?
Forza is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 10:33 PM
Anyone notice oil residue everyone oil change? speeD3m0n2010 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 09-23-2010 08:22 PM
