2011 LS V6 vs 1969 Camaro
2011 LS V6 A6 vs 69' with a 350 4 barrell dual exhausts and all stock.
Who would win? |
Banned
Drives: 2011 Avenger Heat Join Date: Nov 2009
350ci as found in the 1969 Camaro,
(1969 300 hp (224 kW)) @ 4800 rpm, 380 lb·ft (515 N·m) @ 3200 rpm I'm going to go with the 69, 100 ftlbs of torque is hard to overcome. |
![]() ![]() ![]() ![]() Drives: bug Join Date: May 2009
The 2011 V6 should win.
I had just about the same car but it was a 67 with a 350 out of a 69 with edlebrock intake and 600cfm carb, dual exhaust, yada, yada. It was a high 14 second car at best but probably about a 15 flat. Even after the 350 blew and I put a ZZ4 in its place it wasnt much faster until I bolted on long tubes, 750 holley, and 12 bolt rear with 4.10 posi and then it was a high 12's but only after a Hughes TH400 and subframe connectors and lift bars possibly mid 12's if I could of gotten good 60 foots but I never got around to taking it to the track because the the vacuum secondaries on the holley never fully opened or was too soft so I just zip tied the secondary linkage to the primaries so it would fully open when I wanted but drive ability suffered due to all 4 barrels opening together instead of progressive. |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Those old muscle cars stock aren't nearly as fast as the new ones.
Yeah, I'll get around to it...
I'm not sure on the specs, but wouldn t the 69 also weigh more?
#6 |
#7 |
Drives: 1993 Rustang Join Date: Sep 2009
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
Stock to stock I would give the new V6 a pretty easy win. Remember, that rating for the 69 would be gross and the new one in net ratings. i'd say the modern HP rating for that 69 would be lucky to be 250 horses.
#9 |
Thanks,my friend keeps telling me his 69 can beat mine. I said I don't care since mine is way cooler than his since his doesn't even run now.
#10 |
![]() ![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2006 F150 Lariat Join Date: May 2010
#12 |
It's pretty easy to make a 1969 anything run...points get deducted from the meatball owner that can't fix a carb/distributor car...but certainly not from the car itself. Don't forget, it's 42-43 years old.
#13 |
![]() Drives: 2010 camaro ss Join Date: Apr 2011
Exactly!
| CAMARO WIKI | Tran | Wiki | 67 | 11-27-2024 09:02 AM |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| 2011 Camaro pricing & information announced! HUD, Synergy Green, V6 rated at 312hp! | Tran | 5th Gen Camaro SS LS LT General Discussions | 962 | 12-27-2011 05:34 AM |
| 2011 mustang v6 or 2011 camaro v6? your honest opinion. | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 54 | 02-11-2011 01:21 AM |
| Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 11:29 PM |
