Old 04-15-2011, 12:54 PM   #1
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
L99 Spark Plug Change
I'm going to change the spark plugs on my L99. I have a few questions though.
1) What is the torque spec for the spark plugs?
2) Should I use anit-seize?
3) Anything else I need to do or any other tips?
Thanks!
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 04-15-2011, 02:06 PM   #2
Scott@Bjorn3D
Whats wrong with the plugs you have, they are 100K plugs. I would not worry about changing them till 50-75K.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-15-2011, 05:16 PM   #3
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
1) What is the torque spec for the spark plugs? I personally have never tor
Thanks!
I replaced mine last weekend while installing my Stainless Works Headers. I went with the AC-delco's 41-110. factory iridium's. Ted Jennetty tells everyone these are probably some of the best plus for N/A cars. I did use anti-seize and I always tighten my plus by hand and then snug with a 5/8 plug socket.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 04-15-2011, 05:20 PM   #4
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
use anti seize.. ac delco 41-110, tr55IX, weaponX iridium.. etc
they are all the same even a $14 set of NGK tr55's
the more expensive plugs last longer.. proper gap is the usual issue with plugs
an engine doesnt know what plug is in it...LOL
CC Performance is offline   Reply With Quote
Old 04-15-2011, 06:02 PM   #5
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
what's the proper gap on on say the NGK tr55's?
Darth Martel is offline   Reply With Quote
Old 04-15-2011, 06:23 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Thanks!
From the shop manual:
20 Newton meters (15f t lbs).
Anti-seize not mentioned.
Why are you changing the plugs???????!!!!!!!!!
Rock-It Man is offline   Reply With Quote
Old 04-16-2011, 04:42 PM   #7
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
I don't use anti seize with aluminum heads, torque spec is 15 ft lbs. In a stock L99/LS3, I use NGK TR55's, with a power adder or added compression I use NGK TR6's and gap them accordingly based on the engine combination. If you have a cam and aftermarket heads, and your still naturally aspirated but raised your compression, you can make more power on a TR6 plug than a TR55 because you can run more ignition timing. I tested this more than once and was able to get 4-5 rwhp gains doing so.
mike@newera is offline   Reply With Quote
Old 04-16-2011, 05:11 PM   #8
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
I always use anti-seize when I change my plugs. I used NGK TR55's or TR6's on my LS1 engine. I was not sure they would work on the L99 engine. I still have a set of TR55's. I gap mine at .040. I have not changed mine yet on my 2011. I usually change my plugs once a year.
Good luck. Hope they are easier on the L99 than on my old LS1. It looks like you have more room.
Bill
BowlingSS is offline   Reply With Quote
Old 04-16-2011, 05:15 PM   #9
BowlingSS
I would never wait that long to change my plugs. I change mine every year or about 15K. But I also change my oil every 3 to 5K miles.
Bill
Old 04-18-2011, 12:16 PM   #10
Agent WD-40
So two votes for anti-seize one against...
15 lb-ft. Thanks!
I'm switching back to the AC Delco 41-110 long life factory plugs from my TR6 plugs. I was also seeing some misfires (when using the scan tool) on cold startups (under 40 degrees).
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 04-18-2011, 05:45 PM   #11
JTC/C5
JTC/C5's Avatar
Drives: 2010 2SS L99
dont do it... read my thread lol... no need to change AC Delco plugs... trust me
To Be Continued
JTC/C5 is offline   Reply With Quote
Old 04-19-2011, 12:33 PM   #12
Agent WD-40
I am switching back to the stock AC Delco plugs because of your thread!
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
For sale - Katech carbon fiber valve covers, relocation kit, and spark plug wires CNB V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 9 01-20-2011 08:26 PM
MTI racing hot spark plug wires monstertodd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 09-30-2010 10:31 AM
Cam install and spark plug help needed! J-Rod6410 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 08-22-2010 10:55 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
