Old 04-27-2011, 11:52 AM   #1
srsummers
Drives: 2011 Camaro LT Silver
Water Spots on Glass
Hey everyone. Does anyone know how to get water spots off of glass. I have tried a couple of good cleaners but they haven't worked. We have such hard water here in AZ.
Scott
srsummers is offline   Reply With Quote
Old 04-27-2011, 11:54 AM   #2
HaubSS
HaubSS's Avatar
Drives: '11 IBM 2SS/RS LS3/M6
try a 50/50 mix of vinegar and water, worked for me on previous vehicles.
2011 IBM 2SS/RS - LS3/M6 - Grey Interior
Full bolt-ons + TSP 229/236, 112 LSA
Tuned by STARKWEATHER PERFORMANCE
BMR Stage 3 suspension
MRR 288 - 20x10(+35), 20x11(+43)
HaubSS is offline   Reply With Quote
Old 04-27-2011, 11:59 AM   #3
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Theres a few ways to go and it all comes down to how severe they are:
White vinegar is a place to start. It dissolves minerals and if the spots are fairly light thats often times all you need.
If that fails step up to claying the glass. A lot of times the vinegar will help, but not fix the problem so clay will help get what the vinegar can't.
After that if you still have spots move up to an abrasive polish. Something like our Swirl & Haze Remover or Severe Swirl Remover by hand or machine will get the job done. For very well bonded contamination that the clay can't remove sometimes it takes an abrasive to actually scour the surface clean.
Lastly if that fails, 0000 steel wool and lots of glass cleaner. Spray the wool and the glass liberally with glass cleaner and scrub the surface. It won't scratch so long as you keep the wool wet with cleaner and don't press excessively hard.
If after that you have spots remaining you are dealing with water etching, which means there is actual surface damage on the glass where the minerals ate into the surface. This only happens in the most extreme of cases and would require you to replace your glass.
Old 04-27-2011, 12:37 PM   #4
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Copy, paste, save! This is good info, thanks!
Old 04-27-2011, 01:53 PM   #5
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
Invisiglass by Stoners
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 04-27-2011, 02:05 PM   #6
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
We have hard water also. Have to make sure sprinklers can not hit your paint or windows. I hand wash mine under a carport, dry immediately and finish cleanng windows with spray away. No water spots.
n116ebo is offline   Reply With Quote
Old 04-27-2011, 09:20 PM   #7
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I tell you what, my water here leaves the most ridiculous white water spots all over my car every time i wash it. I was at my wits end then i found a miracle IMO. I wash my car and while it is still wet i mist the entire car with Adams detail spray. Wipe it off with their microfiber towel. It leaves a minor haze as it's still moist. Then i fully dry the car with a different dry microfiber towel and it comes out unreal glossy with not one single spot anywhere on the car. The stuff is nothing short of amazing. Makes my factory black stripes pop like nothing else i have used.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 04-27-2011, 11:12 PM   #8
Tantalizer43
Tantalizer43's Avatar
Drives: 2010 Camaro SS/RS
Dylan, or anyone at Adam's for that matter, will not steer you wrong!
Be careful though, once you get bitten by the Adam's bug, there is no cure!!!
Tantalizer43 is offline   Reply With Quote
Old 05-01-2011, 05:12 PM   #9
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
Once the minerals have etched the glass and leave little spots that cannot be
removed by simply wiping with your cleaner of choice, the only thing you can
do is machine polish.
I've tried various hand remedies; Vinegar, glass polish, waxing and even using cerium oxide paste used in glass polishing, but no success.
I HAVE NOT used the PC7424 with polishing compounds YET, but I intend to try on
the glass panels on the shell of my Ram 1500 (severely etched); first with FMP and maybe SWH if I feel the need to get aggressive.
more later...
...maybe (the truck is up for sale)
RiCorvette is offline   Reply With Quote
Old 05-04-2011, 03:21 PM   #10
srsummers
What kind of Clay are you reffering to?
Old 05-04-2011, 03:29 PM   #11
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
A detailing clay, such as Adam's Detailing Clay Bar would do the trick
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
Removing dried water spots?!? TXGooch21 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 8 10-21-2010 01:14 AM
The hardest hard water spots you will ever see! spacecowby Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 34 09-06-2010 12:47 PM
Need advice on removing water spots and how to clean car BaylorCamaro Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 08-27-2010 01:50 PM
