Old 05-03-2011, 10:36 PM   #1
champ22
champ22's Avatar
Drives: 2014 Chevy Camaro 1SS 1LE
Exclamation Weird Noise from the Engine!
Ok, so I just had my car into the dealer for my free oil change and an update on the PDIM module. Today, I was on my way home from work with the radio off when I heard what almost sounded like a watery type of noise coming from the passenger side behind the dash or in the engine bay. What's weird is that it only makes this noise when I get into the throttle a little bit. I can accelerate without making the noise but when I get into it, it almost sounds like water leaking. I'm not sure if this is a new noise but I've only recently noticed it. My plan is to take it to the dealer but was just seeing if anyone had any input on the situation. Any help would be appreciated. Thanks!
champ22 is offline   Reply With Quote
Old 05-04-2011, 12:06 AM   #2
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
It's the coolant pump coming on and sending fluid through the lines. It's a normal sound I believe, but don't take my word as gospel.
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 05-04-2011, 12:23 AM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
There is a TSB on it... they put a valve on the coolant line feeding the heater core to fix it.
Sterling is offline   Reply With Quote
Old 05-04-2011, 07:55 AM   #5
champ22
champ22's Avatar
Thanks for your help. I will be taking it in to get it fixed this week.
Old 05-05-2011, 02:50 PM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
champ22, let us know what happens with your dealership. I'd like to make sure we help you as much as we can. Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Old 05-10-2011, 09:34 AM   #7
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
Glad I found this post. I'm hearing that same kind of gurgling, passenger side, between 2-3K rpm in 2nd on my 6 speed 2SS...
I'll need to take it in.
Thanks a bunch for the post!
Camaroshark is offline   Reply With Quote
Old 05-14-2011, 04:51 PM   #8
Drives: GM Vehicles
Camaroshark, could you also keep us all up to date on how it goes with your dealership as well? Thank you.
Subject:Rattle Noise Under Vehicle - May Be Engine RPM Related venice17517 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 55 09-21-2015 05:53 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
normal noise or weird noise? help!! MClarenF1 5th Gen Camaro SS LS LT General Discussions 12 02-11-2011 11:21 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
