Old 05-05-2011, 11:22 PM   #1
BloodUSMC
Blood Sucking War Machine
Drives: Black 2011 Camaro 2LT/RS - A6
Bluetooth driving me nuts!
I have sprint HTC EVO Shift. each time I get in the car I turn bluetooth on and it connects. I make a call and after few minutes it would disconnect from the car and goes back to the handset without touching anything and without moving anything. Phone is usually in the cupholder locked.
any solution?
BLACK 2011 2LT/RS COUPE. Roto Fab Intake, MRT 1.0, OBX LT Headers, Magnaflow resonated x pipe, Trifecta Tune
BloodUSMC is offline   Reply With Quote
Old 05-05-2011, 11:26 PM   #2
Darth Camaro
Out of my mind!!!
Darth Camaro's Avatar
Drives: 2010 Camaro RS
Don't know. My Bluetooth quit work'in. Can't even connect to any phone GM says its fine. Ya whatever...
Its not a point of where you are going but, how you get there
Darth Camaro is offline   Reply With Quote
Old 05-05-2011, 11:54 PM   #3
MOMSREDSS
MOMSREDSS's Avatar
Drives: 2010 Victory RED RS/SS L99
Love my bluetooth. I haven't had any problems in 3 years. Sorry you're having problems.
2010 2SS/RS, L99, Victory Red, Cyber Gray Stripes, Custom Painted Engine Cover, Tinted Windows, Cold Air Inductions CAI, Pedders Stainless Brake Lines, ARH Long Tube Headers, SLP Loudmouth II Axle Back, BMR Rear trailing arms, BMR Level 3 Performance Handling Package; Build Journal http://www.camaro5.com/forums/showthread.php?t=130448
MOMSREDSS is offline   Reply With Quote
Old 05-06-2011, 12:06 AM   #4
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
take it in for warrenty... have not had any issues with my iphone 4, so if they tell you its the phone there wrong.. Also make sure its updated with the phones new software... There is an update also to the PDIM so make them get you the update or new one...
MARINE1991 is offline   Reply With Quote
Old 05-06-2011, 12:14 AM   #5
5GenCamaroSS
2004 Beast Silverado Z71
Drives: NO MONTHLY PAYMENTS
Send a message via Yahoo to 5GenCamaroSS
I havent had that bad of a problem, but I do have issues when try to call people hands free, i say call, then it says what name and I try and same a contact in my phone and it just says goodbye. I get calls in fine. If I scroll through my phone and hit call on my phone it goes through fine but then it's kinda defeating the purpose of hands free.. More like hands free modified lol
5GenCamaroSS is offline   Reply With Quote
Old 05-06-2011, 12:50 AM   #6
fad1
fad1's Avatar
Drives: Future 5th gen Camaro
I would say to make sure you have the necessary updates for your phone. That might be the problem
Plan: Buy a Summit White Camaro right after College.
fad1 is offline   Reply With Quote
Old 05-06-2011, 12:51 AM   #7
nacho478
Drives: 2011 2SS/RS
I have the exact same phone and have had the exact same problem and my phone has the all the available updates. I wound up just deleting the phone and the car from each others' connection lists and reverting to the earpiece I used before.
nacho478 is offline   Reply With Quote
Old 05-06-2011, 02:44 AM   #8
1up5dn
1up5dn's Avatar
Drives: 2011 Black RS SS
Must be phone related. I have the Droid X and it has worked flawlessly, not had one drop or complaint.
Chris.....
1up5dn is offline   Reply With Quote
Old 05-06-2011, 04:12 AM   #9
Mandog
Mandog's Avatar
Drives: 2011 RJT 1LT Vert
I have a Blackberry and had to change a setting on the phone in order for the Bluetooth to connect automatically, rather than manually each time I got in the car. Your phone MAY have a similar setting.
Go Topless!
Mandog is offline   Reply With Quote
Old 05-06-2011, 06:15 AM   #10
BloodUSMC
The phone connect automatically as soon as I turn on the bluetooth. thats not a problem. but the problem again is it drops while im using it. anyway I will check my phone to see any updates. and try deleting the car from my phone and relink it. even tho i did that before but i will do it again
Old 05-06-2011, 06:22 AM   #11
SILVERHAWK
SILVERHAWK's Avatar
Drives: 2011 2SS/RS, '22 Silverado Z71
The only problem I have with my bluetooth system so far is-- the system will not recognize any of the names for voice dialing for example "Dad's cell phone" instead the system will say that I called out 3-4 rrandom numbers. But, if I say just numbers to dial it will dial them correctly. ?????????????? of course at the dealership when I picked it up-- it worked fine either way go figure
SILVERHAWK is offline   Reply With Quote
Old 05-06-2011, 07:01 AM   #12
BloodUSMC
I think I know the solution to your problem. If you look carefully when someone calls it display last name only. So maybe you have to make sure the contact has a last name and say the last name only. Call lastname.
I'm 90% sure it displays the last name only
Old 05-06-2011, 07:35 AM   #13
champ22
champ22's Avatar
Drives: 2014 Chevy Camaro 1SS 1LE
You may know this by now, but the only way to use voice dial is to store name tags with the numbers into the cars phone system. You can use your phone's voice dial but its more difficult and requires you to say "voice" after you hit the call button. The phone's voice dial never seems to work as well. To store numbers and name tags on the infotaine system, press the call button and say "store". The system will then prompt you to enter a phone number followed by the name tag you want to store it under. Once its in the system, you can then hit the call button and say "call *****". Also, in order to call name tags, you have to say "call" and to dial numbers you say "dial". Check out the infotaine system in manual, it explains it really well in there.
champ22 is offline   Reply With Quote
Old 05-06-2011, 07:45 AM   #14
Wantconvertible
Wantconvertible's Avatar
Drives: 2011 SS/RS VERT
Iphone user no problem with the bluetooth in my Camaro
Wantconvertible is offline   Reply With Quote
Run To The Coast (RTTC) Performance Driving Event Hotchkis Camaro Motorsports Discussions 0 03-26-2011 01:15 AM
New Camaro Convertible Blends Top-Down Driving Fun With Precise Engineering JoeP@TeamBeckyD Camaro Price | Ordering | Tracking | Dealers Discussions 1 11-28-2010 04:08 PM
NORTH SIDE vs SOUTH SIDE! Hosted by Houston Performance Driving November 20th @ LMP! xtc4us USA - Texas 4 11-19-2010 11:02 AM
Seriously, When you're driving FOCUS on driving! Asylum Off-topic Discussions 19 09-09-2010 03:53 AM
2LT/2SS Bluetooth issues? Darsh 007 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 12-01-2009 02:47 PM
