Old 05-06-2011, 09:32 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
amber halo,s
well if it don,t have to do with speed i,m lost..lol..just recd my amber halo{headlight and fog} ..never realizing that with the rs/ss my fogs don,t seem to turn on no metter what i do...what do i need to do to wire these up...i am going to install the halo,s this weekend...do i keep the factory white halo in place-remove it -or put the amber behind it? i have read a couple diff posts on this and i,m hoping someone has done the exact same mod so they can chime in...the manual part i can do, but unclear on whether to remove or keep orig halo and exactly how to wire..aac did send me a switch...do i wire everything to switch and use that to turn on amber halo,s and keep factory exactly as it is...that way they will function as normal...that seems the logical way...1 aac switch activates all amber halo, and without disturbing any gm wiring all lights can be shut down by leaving in off mode...sorry for the long post, just want to get some help..thanks
mikepage0007 is offline   Reply With Quote
Old 05-06-2011, 09:39 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
with the RS package you don't have fog lights. You have DRLs (Daytime Running Lights). You need to remove the stock OEM halo ring. Yes, wire the amber halos to a switch. That would be the easiest way.
Click to view my build thread
Old 05-06-2011, 09:43 PM   #3
mikepage0007
Drives: 2010 camaro
ok , thats what i was thinking, only thing after reading so many posts on this over the last week...i thought i remember ivan saying sometging about mounting amber halo behind stock halo that it gave a better effect...thanks that was half my question..
Old 05-06-2011, 09:51 PM   #4
The Stig
The Stig's Avatar
Yes, you can mount the amber halo behind the stock halo. But in order to do so you need to cut the amber halo ring so that it fits behind the stock halo.
Old 05-06-2011, 09:56 PM   #5
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
if you cut and mount it behind the halo you wont see the leds as much....
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 05-06-2011, 09:57 PM   #6
mikepage0007
Drives: 2010 camaro
i guess i,m gonna have some headlights for dinner tomorrow..lol
Old 05-06-2011, 09:58 PM   #7
mikepage0007
Drives: 2010 camaro
is that good or bad...i believe that was what ivan was saying that it gave a smoother appearance?? sorry i,m pumping for info, its just not something that is easy to change once i get them open tomorrow.
Old 05-06-2011, 10:46 PM   #8
Capthowdy
Capthowdy's Avatar
thats a good thing....the look of the indv leds is what everyone tries to stay away from...I am working on a mod for the stock halo ring...going to put a RGB led in with a controller in place of the stock white led..better looks and cheaper also...
THE "MENACE"
Old 05-06-2011, 11:37 PM   #9
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
you keep the factory ring do not cut the aac halo, you cut the factory ring, its all in the instructions
camaro4mybday is offline   Reply With Quote
Old 05-07-2011, 01:13 AM   #10
mikepage0007
Drives: 2010 camaro
okay, i saw that when they say on dvd" optional cut off top of original ring"..that is what i want to do...so when you turn on seperate switch for amber halos, the stock rings will not be on , the amber light will pass thru them? correct?..my friend builds some serious sound systems and has access to equipment they use to cut lucite and plexiglass for special enclosures ..he could prob cut me something similar for fogs , so they match evenly..what do you think? thanks for helping a newb on this stuff
Old 05-07-2011, 09:12 AM   #11
The Stig
The Stig's Avatar
Yes you can cut the stock OEM ring. That is what I did with my install. Just took some bolt cutters and snipped right through the plastic
Old 05-07-2011, 09:21 AM   #12
mikepage0007
Drives: 2010 camaro
alrighty, evrything sounds good, will tackle job today and post back pics when done...
Old 05-08-2011, 10:54 PM   #13
mikepage0007
Drives: 2010 camaro
just wanted to say thanks for everyones input...could not make myself cut the white halos up, seemed like a perfectly good waste of a nice halo...lol
Old 05-09-2011, 04:41 AM   #14
AzTeK
AzTeK's Avatar
Drives: 2011 Camaro SS
if you wanted white also, you could of bought the dual color white and amber. worked out well for me.
AzTeK is offline   Reply With Quote
How to get my Amber Halo's as DRLs? ihaveacamaro Cosmetics and Lighting Modification Discussions 31 12-07-2016 10:42 AM
New style AAC Plasma DRL P13w bulbs in Amber? SIMSS Cosmetics and Lighting Modification Discussions 4 01-20-2011 01:47 PM
Amber Or Red ? JAB Cosmetics and Lighting Modification Discussions 20 11-30-2010 09:48 AM
My last AAC halo question.. Should every other LED be amber, or Amber and white InvaderMoose Cosmetics and Lighting Modification Discussions 2 05-08-2010 07:16 PM
Anyone have pictures of Amber Halo's on a yellow car? Rickerbucks Cosmetics and Lighting Modification Discussions 1 03-30-2010 09:06 PM
