Old 05-11-2011, 11:34 AM   #1
dr.camaro
Drives: 2010 camaro ss (L99)
camshaft stages?
I've heard there are 3 stages of cams, like comp cams stage 3. what does that mean? Are the TSP 231/236 cams = stage 3 ?
2010 Camaro SS-L99-Inferno Orange
K&N CAI, JBA offroad connection pipes, BORLA ATAK catback, dyno tuned, 352 RWHP 366 RWTQ
dr.camaro is offline   Reply With Quote
Old 05-11-2011, 02:47 PM   #2
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
Stage names are just made up by the manufacture, and usually indicate the level of aggressiveness of the cam. stage 1, slightly more aggressive than stock, 2 more, 3 even more but probably starting to push the limits of what you are going to get out of a cam HP wise.
At least that is how I understand it...
460 at the wheel so far...
VMS Stage 2.5 Camshaft Kit- Comp cam LSA 114,227/239, .613 .623, RotoFab CAI, VMS ported intake manifold,Kooks 1 3/4" headers with HF cats, Corsa Catback, VMS custom dyno tune,TechAFX engine hose relocation kit, DSS 1400 hp axles, BMR toe rods and links, LS9 Clutch, Hurst short throw with roll out, Liberty Gear built tremec 6060.
KMSRS2SS is offline   Reply With Quote
Old 05-11-2011, 05:02 PM   #3
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Back in the day it was 1/4 cam 1/2 cam 3/4 cam or full .
Talk to someone with experience to get a cam that suits your needs .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 05-12-2011, 01:24 PM   #4
barnesql
Drives: 95' Z28, 2010 2ss RS
The higher that stage refers to the aggressiveness/lift of the cam, right?
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback
Off road x-pipe
Kooks LT Headers
barnesql is offline   Reply With Quote
Old 05-12-2011, 01:31 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Yes... basically a way for shops to easily describe their cam w/o getting into all the numbers
Old 05-13-2011, 03:10 AM   #6
dr.camaro
Thanks guys for your feedbacks, but anybody knows which heads are the best to work with Comp cams?
Old 05-13-2011, 07:27 AM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
The stock ones... but since you have an L99 and will prob be removing heads to change lifters, I went w/ Scoggin Dickey. Mast also has some great heads. Still not much to gain over the stockers...
Old 05-13-2011, 08:36 AM   #8
InfernoCamaroSS
InfernoCamaroSS's Avatar
Hey im new here but I was wondering would the engine be as reliable with a cam. I was wanting to do a cam and longtube headers with a 3 in x pipe high flow cats and loudmouth exhaust on a l99.
InfernoCamaroSS is offline   Reply With Quote
Old 05-13-2011, 08:46 AM   #9
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
You grind the cam to suite your needs.. you dont buy heads to suite a cam
Inferno yes the engine can be just as reliable.... as long as the valvetrain is setup correctly and it isnt to big... bigger cam wnat more rpms to make power.. very hi rpms are a concern but can be dealt with with the correct valvetrain components.. its more reliable than a blower on an engine not built for it
CC Performance is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
"Ghost cam" tune for a v6?? Jason@JacFab Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 572 10-01-2017 06:45 AM
L99 VVT / AFM Camshaft Dyno Results & Explanations Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 90 11-27-2010 08:21 PM
Camshaft moving too far. Camshaft position sensor cant determine position gohwkis Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 07-15-2010 05:00 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 12:00 AM
