![]() ![]() Drives: 2011 Challenger SRT8 6.4L 392 Hemi Join Date: Jul 2010
If YOU HAVE LT HEADERS PLEASE READ!!!!
For those out there with LT headers and custom tunes are you having any problems getting through the emissions process? I have been trying for 2 months to get through it and I have been working with Ted, but I am being told after a 3rd emissions tune that I may have to change out the headers to get it to pass. In TN all readiness monitors have to be in the "Ready" state and no CEL for it to pass.
This morning I got the dread CEL P1133 DTC P1133 Circuit Description The powertrain control module (PCM) monitors the heated oxygen sensor (HO2S) activity. Within a 100 second test period, the PCM counts the number of times that the HO2S signal voltage crosses the rich-to-lean-to-rich thresholds. If the PCM determines that the HO2S did not switch enough times, DTC P1133 will be set. A lean-to-rich switch is determined when the HO2S voltage changes from less than 300 mV to more than 600 mV. A rich-to-lean switch is determined when the HO2S voltage changes from more than 600 mV to less than 300 mV. Vendors and those with this experience please chime in.. Thanks for your time!!
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474 Last edited by RAYSRT8; 05-24-2011 at 08:18 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Last time I had an issue get my car inspected I had to have all but 2 monitors in readiness mode. I had a CEL on my '01 Impala from a bad spark plug. I used a scanner from Autozone to figure it out and then cleared it. If with the CEL gone it wasn't in Ready mode. They told me it could take 50 - 100 miles to get the monitors back into "Ready" mode after they had been cleared.
I had to go get on the highway and drive a while and then came back. After two attempts at that I got it in ready mode in order to pass. Maybe your monitors haven't had enough time to get into "Ready" mode after the tunes. Go drive it 50 miles or so and have it inspected again.
Build Journal ![]() |
Yeah.. I got the dreaded CEL this morning P1133...
DTC P1133 Circuit Description The powertrain control module (PCM) monitors the heated oxygen sensor (HO2S) activity. Within a 100 second test period, the PCM counts the number of times that the HO2S signal voltage crosses the rich-to-lean-to-rich thresholds. If the PCM determines that the HO2S did not switch enough times, DTC P1133 will be set. A lean-to-rich switch is determined when the HO2S voltage changes from less than 300 mV to more than 600 mV. A rich-to-lean switch is determined when the HO2S voltage changes from more than 600 mV to less than 300 mV. I contacted Ted back at this point and he stated that I may have to put teh stick headers back on for the test... Surely there is a way around this and that would be a pain in the butt to do that every year.
Flowmaster American Thunder Series Cat Back Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474 |
Depending on local law and how the tests are conducted it can be very difficult, even impossible, to pass emissions tests with headers and high flow cats. In some places, any modification to the stock exhaust from the cats forward is an automatic "fail".
#5 | |
Thanks Chase.. In TN as long as we have CATs and all the sensors we are good, but it has to be acheived with no CEL and all the monitors in the "Ready" state.
#6 |
NCM-WINR
Drives: 2010 SS/RS IOM 2014 2LT Stingray Join Date: Mar 2009
I had a fail after a tune. The mechanic told me I had to let it cold soak for 8 hours then put some miles on it and bring it directly to him. I put about 50 miles on and passed. Just passed my first inspection with headers and high flow cats with no problems
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
#7 | |
Do you know what all was involved and was it for the same code I posted P1133? Thanks, Ray
#8 |
![]() Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
I installed spark plug antifoulers in my rear sensors, and "did not turn off those sensors",
they have been like that for over a year and have had no CEL's. I did the same thing to my buddys 08 Bullet after he was having the same issues "and not able to get it inspected", after installing the antifoulers he had all the emissions related items turned back on, and has passed for the last two years. and no CEL's to date. |
#9 |
i get codes p0420 p0430... had them taken off by my tuner... no trouble since.
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
what tuning software are you using?,, with hp tuners you can tune these codes and the status will read complete/pass
![]() Last edited by camaro1; 05-24-2011 at 12:45 PM. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
X2. Set them to "No Reporting"
She is only memory now. |
#12 |
Bingo!!,, he probly doesnt have this option with just a hand held tuner,, you will need hptuners, efi live or OBD2 Tunercats
#13 |
+1 in most cases these days you can pass an emmisions test with a professional tune. We've taken some pretty extreme cars into inspection with our fingers crossed and passed. One guy even commented on how sick our car sounded. Supercharged/cammed/long tubes and no cats. He asked us to rev it up for him after we passed.
So it's all about making sure you tune those codes out. We sell everything you need to tune cars yourself but unless you know what your doing we recomend you get a tune done by a professional.
#14 | |||||
Thanks to everyone that replied and I appreciate everyones time with this.. This is a great site in which everyone tries to help others out in their time of need.
| Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
| MagnaFlow Catback, C.A.I. Intake, StainlessWorks LT Headers, HighFlow Cats, and Tune | Gnarlygianni | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 10-01-2010 07:41 AM |
| Transformer Edition Camaro Questions | 2010bumblebeeSS | 5th Gen Camaro SS LS LT General Discussions | 17 | 04-21-2010 10:05 PM |
| looking for lt headers | spryc5 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 04-19-2010 10:03 AM |
| LT Headers with no tune | Stealth 2010 2SS/RS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 03-08-2010 07:44 AM |
