Old 05-26-2011, 08:01 AM   #1
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
TVS2300 10psi 600rwhp !!!
Hi,just done adding 8rib + Cog drive + JRE tensioner setup for my TVS2300 + these mods :
-3.3 blower pulley & overdrive dambener pulley.
-Ported heads with larger exhaust valves.
-JRE smooth idle blower cam.
-ARE lt with custom 3" resonated x pipe & slp powerflo mufflers .
-FastLane cold air.
-BAP + FastLane dual fuel pump setup.
Car made 600rwhp @ 10psi then drops with no slipage to 6psi & loses power up top !
My concern is that the Magna cannot make it up feeding the heads which causes boost drop & not making power as planned.
Car made 595rwhp with 3.4 6 rip @ 6psi with stock heads & ComCams 227/248/113.
Thanks,Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 05-26-2011, 10:42 AM   #2
HumanWiki
Drives: Car
I have an OD Cog for this system if you'd like to buy it.. Was only on the car for 1 dyno run and came off due to too much boost. It would help with your slippage issues since you could run a larger pulley up front and use the cogs in rear.... unless you're already doing that --
HumanWiki is offline   Reply With Quote
Old 05-27-2011, 02:59 AM   #3
alssiri
alssiri's Avatar
I allready have the 1:1 cog drive & JRE tensioner, what i am trying to say is that i should get more power with the extra 3psi + ported heads & thinking that the blower is reaching its limit feeding the ported heads & loosing boost without slipage on top, in 3rd gear boost didnt drop & made same power , in 4th gear same power then drops boost to 6psi , i am just trying to see if something is wrong there.
Ahmad
2012 ZL1 A6 (SOLD)
Old 05-27-2011, 05:55 PM   #4
HumanWiki
Drives: Car
Ahmad
Ah.. ok.. Yeah, can't help you there.. I'm still new to the FI world.. but, there are people with Autos making more power with a TVS than what you're putting out -- so, i don't know if I'd count the maggy out yet.
Old 05-27-2011, 08:28 PM   #5
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
See my signature below showing my mods and hp/tq numbers with ported heads,Maggie,3.6 pulley,etc.
Something definetly is not right with your build.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 05-28-2011, 12:07 AM   #6
alssiri
alssiri's Avatar
On what dyno are your #'s Mustang or Dynojet ?
Ahmad
2012 ZL1 A6 (SOLD)
Old 05-28-2011, 12:36 AM   #7
Warhorse
Warhorse's Avatar
Drives: 2011 Syn Green Camaro
-FastLane cold air.
Thanks,Ahmad
"BELT SLIP"
If you have a magnason tensioner even with a 8 rib pulley your probably still slipping. I had to go to a Linginfelter super duty tensioner to solve slip issues and I allready had the 10/14 rib conversion. I originally tried the Katech non spring loaded tensioner and it would prevent slipage but if you forget to disable Traction Control the computer would cut throttle off and on to control traction and cause shreddred belts. We found that the belt needed some give to live.
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!!
Warhorse is offline   Reply With Quote
F/S 3.00" Pulley TVS2300 gets 10psi jrpxxii Forced Induction 12 03-12-2011 12:41 AM
Cold Air Inductions TVS2300 Version Installation Issue DNA Forced Induction - V8 3 10-27-2010 02:15 PM
Whipple vs. TVS2300 audiomikej Forced Induction - V8 18 09-21-2010 10:10 PM
Used TVS2300 opinions and thoughts... JProberts Forced Induction - V8 1 09-17-2010 12:21 AM
Magnacharger 2010 TVS2300 GP - A Couple Options For Folks Mike Norris Forced Induction 3 08-27-2009 03:01 PM
