Old 05-31-2011, 09:23 PM   #1
xpanda305x
Banned
Drives: Dark Knight
Does DRL ( non RS ) Mess with hids? how to fix it?
okay i have a problem that in the day time only 1 hid would turn on and such. and at night time they both turn on no problem or question. so my question is the DRL during the day time ( remember im NON RS and no fogs so my headlights are DRL) be messing with that? how can i fix that?
someone told me a relay would fix it? a hids relay? would that fix that?
someone told me to turn off DRL...how can i do that?!
xpanda305x is offline   Reply With Quote
Old 05-31-2011, 09:57 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Hi if you are having problems its your lights, If you look at the connecters going to the bulb you will see the connecter looks like its burnt, Is this right?
Old 05-31-2011, 10:22 PM   #3
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Is it your drivers side HID that comes on constantly, but your passenger side doesn't?
If you turn your headlights on fully, then back to auto during the day, both lights are on?
The DRL doesn't supply enough power to fully ignite the HIDS during start up, thus 1 is on, the other is off. I had the same problem, had to use a relay with a module that will cancel out the PWM signal to prevent the relay from chattering.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 05-31-2011, 10:40 PM   #4
xpanda305x
Banned
Drives: Dark Knight
^ english please?!?! haha
Old 06-02-2011, 08:54 AM   #5
xpanda305x
Banned
Drives: Dark Knight
Old 06-02-2011, 09:03 AM   #6
MagnumForceGB
You either need to get a relay harness, or every time you start your car up during the day, turn the light knob all the way to the right, then back to the left (turn on full headlights, then back to auto).
The Daytime Running Light signal isn't strong enough to start up the HID ballasts some times. Its fine for running them once they are on though.
Old 06-02-2011, 09:49 AM   #7
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Drives: '10 Black Camaro
Get these... they worked for me. You are using a relay right?
http://www.v-leds.com/Exterior-LED/D...-p6160696.html
Tx1Lt is offline   Reply With Quote
Old 06-02-2011, 10:13 AM   #8
BLACK10
BLACK10's Avatar
Yes you def need a relay/harness
Old 06-02-2011, 10:14 AM   #9
BLACK10
BLACK10's Avatar
This has to have a harness to work properly also
Old 06-02-2011, 12:48 PM   #10
xpanda305x
Banned
Drives: Dark Knight
huh? isnt what i need a hids relay?
http://www.automotivelightstore.com/...ayharness.aspx
Old 06-02-2011, 01:14 PM   #11
2SSRS@Gen5diy
What company HID do you have.
Old 06-02-2011, 03:29 PM   #12
BLACK10
BLACK10's Avatar
thats what you need
Old 06-02-2011, 03:31 PM   #13
GTPprix
I hack cars.
Drives: Lots ;)
OR we can program your DRL's off as part of our custom BCM programming
Chris White
Some uhhhh cars.
GTPprix is offline   Reply With Quote
Old 06-03-2011, 09:46 AM   #14
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Originally Posted by BLACK10 View Post
thats what you need
Cool, hadn't seen those.
BC Camaro's Merc Canada 548 08-16-2015 11:53 PM
Need HELPPPP with DRL and HID's Can't_C_Me Cosmetics and Lighting Modification Discussions 2 12-31-2010 07:44 PM
Anybody heard of a fix for non RS HID headlights "not aftermarket" yet?? DFS88 Cosmetics and Lighting Modification Discussions 33 02-27-2010 04:49 PM
Winter tires & wheels for RS Camaro, smaller size then 20 inch mess up the odometer? ladysman07 Wheels and Tires Talk Sponsored by The Tire Rack 5 09-08-2009 04:57 PM
