![]() Drives: 68 SS clone,2011 2LT RS convertible Join Date: Jan 2009
Vibration at 1200 RPMs
Just got the 2LT V6 auto convertable. I love it
knows 2 facts about ducks
I'm not a professional by any means, but it might be the engine lugging? My first guess was AFM, but then I saw that you have the V6. wish I could be more help.
Mother of PWA Babies
Drives: 2011 RJT 2LT/RS Join Date: Apr 2011
I have the same problem. I will be watching this thread.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
My car does the same thing. I took it to the dealer to look into this. They told me since it's an auto and the transmission uses a torque converter opposed to a clutch, the RPM at that range creates shutter from the slower spinning of the torque converter. Kind of makes since, considering the torque converter is filled with fluid. Any thoughts on this?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: X-15 Velocipede Join Date: Mar 2008
The torque converter is a fluid coupling. You may feel some shudder when at part throttle and the trans is shifting to a higher gear. You also may notice when the converter locks and unlocks. But, if it's a constant vibration with steady throttle and no shifting - torque converter issues have a low probability of involvement.
Have a good tech duplicate it with you on a test drive, and they may be able to find better direction for diagnosis. |
#6 |
![]() Drives: 2011 RJT Camaro RS Join Date: May 2011
I just got a 1lt RS on friday and i have the same issue, as soon as I let off the gas or hit a higher rev count it stops. Im guessing this is normal?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Fiat 500 Abarth Grigio Join Date: Apr 2011
There are multiple threads on this and i think no one has a fix or most dealers say its normal or having someone from gm come look at it to see if anything can be done.
#8 |
idiot-genius
Drives: 2014 SS Join Date: Jun 2011
My 2LS has 3000 miles on it and I have that vibration... its annoying... took it to the dealer and told them the vibration gets so bad, I can't see out of the rear view mirror, and what do they do?
order a stupid new mirror. Idiots. |
#9 |
"To Punish And Enslave"
Drives: B E RS GBA #72541 3564 CC 220 CI Join Date: May 2011
mutiple threads on this mine does the same thing but i drive in M now when the vibration gets back i just downshift fixes it this is one of the reasons i stoped driveing in D to slove this low rpm vibration it does it right where you state right around 40 to 45 mph
i brought it to the dealer they did there tests and even sent a tech out driveing with me he felt it too and then i test drove a white 1lt rs mirror image to my car did it same spot but not as bad as mine im still waiting for gm to figure out wtf causes this
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession 90% canadian 10% mexican 100% american muscle :flag2: |
#10 |
Love me some Tacos
Well mine does this and I think its the shift points. I dont think my car really needs to be in sixth when going 40? When I put it in M sport mode it mostly goes away. A simple fix (well my simple mind thinks) Change the shift point to keep the car in 5th or even 4th. When I paddle shift it at 40 into 5th or 4th the vibration goes away. It does not just do it at 40 mph. Just depends on gear and speed.. I've seen this even at 50 the car is in sixth doing about 1100 rpms. Shift to 5th car is happy. Not so sure, sometimes I just take my foot off the gas and it goes away or push it to a higher RPM.
#11 | |
i do the same thing driveing i shift just at 2k alittle below or above on a good shift and i rarely touch 6th gear only when i hit 50 mph i switch into 6th good shift point for it
#12 |
![]() ![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
For those who have the manual trans, a thread was started and the OP kept track of everyone having the 1st to 2nd grind issue and then fired all the info to GM. Since I've personally read no less than 6 threads on the auto trans vibration issue, I would suggest that you folks with automatic transmissions create a similar thread and then blast GM. All the people having this issue with the auto trans have been told it's "normal" by the dealer. Clearly it's not. TSBs come from "out of tolerance" behavior. This seems to qualify.
Anyway, another 2 cents for the pot.
#13 | |
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Jeff Morris, Chevrolet Customer Service |
| Vibration from 58 to 68 mph. | Basenji | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 76 | 06-16-2013 11:56 PM |
| Troubleshooting help........ possible car problem....... vibration....... | PQ | Wheels and Tires Talk Sponsored by The Tire Rack | 234 | 12-17-2010 05:01 PM |
| Vibration from 58-68. | Basenji | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 06-13-2010 11:35 AM |
| Vibration in third gear at low rpm's ? | Eduk8r | 5th Gen Camaro SS LS LT General Discussions | 9 | 12-28-2009 10:38 PM |
| Any other LS3 owners have a bad vibration sound at 1500 RPMs | Johnyoder | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 18 | 07-23-2009 05:25 PM |
