Old 06-13-2011, 10:46 AM   #1
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
LIne Lock and Service Stabilitrak
Ok I got my SJM linelock in, bled the brakes and all seems fine. MY problem comes around when I engage the linelock. As soon as I start a burnout my Service Stablilitrak comes on. I am turning off the TC all the way with the 8 sec hold down, but the warning always comes on. Any ideas?
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 06-13-2011, 10:51 AM   #2
NVMYSS
NVMYSS's Avatar
Drives: 2010 Camaro SS
Happens on a dyno as well, because your rear wheels are spinning at a high MPH and your front wheels are not moving.
NVMYSS is offline   Reply With Quote
Old 06-13-2011, 10:52 AM   #3
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
I think someone else said they had the same issue. But it is reset when the car is turned off and restarted.
Not sure there is a solution for this??
Fishdadddy is offline   Reply With Quote
Old 06-13-2011, 11:11 AM   #4
flyby
Drives: 2010 Silver SS
Yes, this is normal. Have used mine many times and it does the same thing. Once you shut the car off, restart it, drive a few feet, shut off again and restart it the message will go away. No change in car performance will be noted. Hope this helps.
flyby is offline   Reply With Quote
Old 06-13-2011, 03:16 PM   #5
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Thanx, thats what I wanted.
Build Thread
Old 06-13-2011, 10:40 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
sometimes does not reset right away...once i had to drive 20 miles , and go in the hse, then came out and it was gone...i don,t think anyone knows exactly, but i tried 10 restarts, and still there...but it will go away
mikepage0007 is offline   Reply With Quote
Old 06-13-2011, 11:57 PM   #7
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
I think its more of a time reset then anything. I got error before and just parked for about 10 mins while I ate and when I came back it was gone.
Build Thread
Old 08-19-2012, 05:52 PM   #8
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
you get 2 abs codes.
has anyone tried pulling abs fuse for when at track, as i wouldn't recommend disabling a safety system when on street......
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 08-19-2012, 06:38 PM   #9
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Pulling the fuse will also throw codes.
SUX2BU is offline   Reply With Quote
Old 08-19-2012, 07:17 PM   #10
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Completely normal. Someone on here had a nice setup connecting a relay in place that dropped power to ABS module while Line lock is activated and then when releasing the lock it puts power back to module therefore no codes where set. This way would be beneficial to those who wish to still have stabiltrack active for correcting the car if it were to get sideways.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Line Lock Brake Control Question with TCS Z Madness V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 03-17-2016 06:55 PM
SS/RS Line Lock chevyss Suspension / Brakes / Chassis 8 08-27-2013 12:32 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Camaro info from GM dahulk 5th Gen Camaro SS LS LT General Discussions 5 03-01-2011 11:39 AM
line lock question paslag Suspension / Brakes / Chassis 3 09-23-2010 06:36 PM
