Old 06-14-2011, 02:13 AM   #1
98_Camaro
98_Camaro's Avatar
Drives: 2016 2SS Coupe
Replacing the window motor?
Hey gang! It's been a while, huh?
ANYWAYS, it looks like I've got Vi all nice and ready for summer, with the exception of two things:
-A broken speaker I've had since Day 1 an never really bothered to fix.
-The driver's side window motor is starting to take a big #2 on me.
While the speaker isn't so much a concern as a luxury, I feel the real problem with the window motor is that if I ever get pulled over by an officer, well, I don't think they'll feel too safe with my window only half down. "Sorry! My window motor kind of sucks! :(" might not get me out of a ticket either...
So I've decided to take on the mundane task of replacing it myself! My main concern is the level difficulty related to replacing the motor, which from what I've picked up around the board here, is a REAL PITA.
I guess I was just looking for feedback. I think it would be a neat little day project, but I could just as easily take it to a dealer and get it fixed in no time flat.
Thoughts from those of you who've had to deal with this?
Gone but not forgotten:
1998 Bright Purple Metallic Camaro
2012 Carbon Flash Metallic 2SS Convertible
2016 Summit White 2SS Coupe M6, NPP, & MRC
Now Driving:
2016 Torch Red Corvette 2LT, NPP, MRC
98_Camaro is offline   Reply With Quote
Old 06-14-2011, 02:40 AM   #2
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
I have no input other than to say:
Where the hell have you been!?
I've seen some write ups on window motors. Does seem like a PITA, I saw stuff about rivets and I just closed the page immediately
Hope it goes smoothly, then when you're done you'll be lookin good driving with the window ALL the way down. good luck! :party0038: <-- LOL
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 06-14-2011, 06:33 AM   #3
94REDVERT
Drives: 94 Camaro Convertible
it isnt so bad, i did mine myself and it took me about 30-45min to complete. its can be a PITA but if you have the right instructions its no so bad. GOOD LUCK!
Trans Am or SS???
94REDVERT is offline   Reply With Quote
Old 06-14-2011, 06:35 AM   #4
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
If I stop by the body shop, I'll shoot some pics and give you some pointers on how to rivet it properly.
Rivets stick better than the screws provided. Nuff said. Also, 1" drill bits. And be prepared to drill out the hole bigger to fit a pop rivet gun. May look unsightly, but with the door panel on, doesn't matter.
Zabo is offline   Reply With Quote
Old 06-14-2011, 08:30 AM   #5
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
When I had my 97 Z28 I had to replace the passenger window motor. I found a good write-up on the net and was no big deal. And while you have the door all torn apart you might as well fix/replace that door speaker, that is unless the speaker is elsewhere.
nancygrl is offline   Reply With Quote
Old 06-14-2011, 08:35 AM   #6
RED CHEVY Z28
RED CHEVY Z28's Avatar
Drives: 2002 Chevrolet Camaro Z28
I have changed both door window motors 4 gens are know fro them remider to disconnect ur battery so u don't have to bost it when ur done.
RED CHEVY Z28 is offline   Reply With Quote
Old 06-14-2011, 09:34 AM   #7
ya boy willz
ya boy willz's Avatar
Drives: 2011 IOM LS, 2011 CGM LS
http://shbox.com/page/windowmotor.html
That link contains a step by step process with pictures. No need to drill out the bigger rivets like some other guides tell you to either. I did it this way with my 4th gens driver side window and it was pretty easy.
Make sure you take your time removing the door panel, and remember that it slides UP, and you DON'T pull. You don't want to rip off all of the tabs. We picked up our Window Motor from our dealership and if iirc it was decently priced. I think it was only a few dollars more than the ones online, and once you add in shipping it evened out. Good luck on your venture!
2011 IOM LS - Drag DR 19s 18x7.5, Projector/Halo Fogs, Blacked out Gills, Red Calipers, Factory Spoiler, 15% Tint
2011 CGM LS- Injen CAI, Vmax Ported TB, Vmax Black Ice O'Lator, Carbon Fiber Bowties, Carbon Fiber Gills, Factory Spoiler, Stock SS Exhaust w/ Magnaflow x-pipe welded in & stock muffler delete, Miro 112 18x8.5 +35
ya boy willz is offline   Reply With Quote
Old 06-14-2011, 10:30 AM   #8
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
My driver window is officially D-E-D, dead as well :/
Had to leave it in Bakersfield with Eme's parents after the BBQ on Sat, as they have a garage.... :(
Sooooo
PS, how the hell have you been 98??
Old 06-14-2011, 04:57 PM   #9
Zabo
Gunning for Sixth
Zabo's Avatar
This is the exact guide I used, and I had never seen the inside of a 4th gen door until I started following the steps. Worked like a charm. Though like I said earlier, I had to drill a few extra holes because I 'missed' the points where I could drill out the stock motor's rivets.
Either way the next time I do it (new door has fact. motor) I'm going to measure where I drilled off the old door and drill pilot holes for 'down the line'.
Because even if you use the best (Doorman, AC Delco)..
The reason these fail is the way GM wired the motors into the car's electrical system. Long story short, the passenger motor piggybacks off the drivers side rather than off the main bus. Less power, burns up the motor because it works harder. :/
Old 06-14-2011, 08:41 PM   #10
98_Camaro
98_Camaro's Avatar
Sooooo
Wow! I'm feeling the love!
I've been INCREDIBLY busy with all my end of the year stuff. It was seriously testing, finals, and senior project back to back to back. Glad to say that it's finally over and that I will graduate Thursday evening with honors!
As far as that goes, I think there's a slight possibility that I might have demoted myself back to lurker. I guess I'll have to work my way back up now that summer's here, gas is still $3.89 a gallon, and I'm flat broke.
I figure I'll go ahead and take care of some DIY projects on the Camaro, either to make it that much easier to live with when I attend school in the fall or help resale value if I decide I need something a little more fuel efficient and comfortable (). If I fix it up nicely, it should be good for about $3500 trade-in, easy.
Thanks for the link! I'll definitely make sure to check it out when I decide to brave the innards of my Camaro.
Now Driving:
Old 06-14-2011, 11:41 PM   #11
ya boy willz
I had the same fear, that I would end up drilling someplace completely wrong and ruining something, but I ended up being just fine. Just gotta try to ballpark it really well.
No problem man . I have it bookmarked, waiting for when the passenger side goes out, so I can do that one also.
Old 06-15-2011, 01:56 AM   #12
Bulldogwinters
SS #2431
Congrats, I didn't realize you were a senior! I still have one more year!
Gas here is around 3.79 (for premium of course)... And by more fuel efficient.. I hope you mean a new 5th gen V6??
Old 06-16-2011, 03:01 AM   #13
98_Camaro
98_Camaro's Avatar
Yeah, I guess a lot of people didn't know that.
That $3.89 was for UNLEADED.
And no, it wouldn't be a 5th gen V6, much to my dream's soul-crushing end. I've been looking at the new Ford Focus considering my dad is a Ford employee (because Chevy's never break ) and can get a lovely discount on the car.
Plus, I think they're pretty snazzy.
Now Driving:
Old 06-16-2011, 03:13 AM   #14
Revo1
Drives: 2010 2SS/RS
98, ya know I never noticed you're also a CA victim??? x10
Gas out here is murder... That's one thing I love about the '02: it doesn't get it's panties in a twist if I put in 87 from time to time
Passed Inspection, needs New Passenger Window Motor Moorepheus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 03-17-2011 11:21 AM
Is it illegal to accelerate fast? crewxp 5th Gen Camaro SS LS LT General Discussions 101 02-15-2011 06:01 PM
Help with window gunk! scythezo6 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 01-14-2011 05:24 PM
Window Indexing Merlin1187 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 07-13-2009 09:07 PM
Removal of power window motor on a 1988 Iroc Z camarolt76 3rd Generation Camaros 3 07-05-2009 08:09 AM
