Old 06-19-2011, 07:55 PM   #1
Dmundz
Dmundz's Avatar
Drives: 2010 Cyber Gray 2SS/RS
Does replacing factory ba amp make a big difference
Well as the title says I'm debating on replacing the factory amp. But not sure if it's worth just doing that or will I not see a huge difference.
I have already added 2 kicker l7's with the early harness from Steve at ********. But am getting annoyed that my highs and mods can't keep up with the bass and our drowned out.
Anyways would love anyone input.
Dmundz is offline   Reply With Quote
Old 06-19-2011, 08:15 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes. If you search for some of SparkAI's threads you will see that a lot of people have replaced the factory amp. I believe that the factory amp is only 60 watts, but I could be wrong on that. Either or, it being 60w is pretty limiting.
Click to view my build thread
Old 06-19-2011, 08:21 PM   #3
crewxp
Drives: 2LT RS Summit White Camaro
Let me just say now that's it's based on personal preference.
To me it doesn't really make much of a difference. It makes things more crisp, but not immensely different. I think replacing the speakers would make the biggest difference. It sometimes still sounds too high (nasal voices) and cracks if it goes too loud.
Although my bass isnt as loud as i want it to be (like your kicker setup), feel it doesn't keep up either.
crewxp is offline   Reply With Quote
Old 06-19-2011, 10:15 PM   #4
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
In my opinion, it was totally worth the upgrade. Replaced mine with the JL Audio XD400 and it made the BA speakers really come to life. But if you're going to upgrade, you may as well do it right. So I replaced the BA speakers with Alpine Type-R speakers.
Old 06-19-2011, 10:28 PM   #5
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Yes!!!
kevin1106 is offline   Reply With Quote
Old 06-19-2011, 10:50 PM   #6
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
OP I started out the same as you with the ******** bass harness, amp, and sub (just one for me) and later added the second set of wires (they are already in your harness) and added the other stuff Steve sells (second harness and 6x9 tweeter bypass) and a second 4 channel amp.
Steve's kit worked great and yes, there is some improvement. However the difference is not all that great. Maybe replacing the speakers is needed.
But I am not happy with this setup. I am going to take out both amps and the passenger side amp board and go with a single 5 channel amp.
It will sound about the same, but will save weight. Since you have 2 subs already this would not be a good direction for you.
Old 06-19-2011, 11:53 PM   #7
manchimp
manchimp's Avatar
Drives: 2010 CGM 2ss
Sounds so much better with new amps and a sub!
manchimp is offline   Reply With Quote
Old 06-20-2011, 12:25 AM   #8
JohnnyComeLately
JohnnyComeLately's Avatar
Drives: 2010 SS/RS
I'm in the process of dialing in my system. 4 channel PPI A404 bridged to run fronts and 600 for sub. No rears right now (have an Alpine later for that).
Factory speakers are junk. I'd almost so those first before an amp, if you are short on money.
The factory amp drives 5 speaker and it's about 6 inches by 4 inches on a single board. It's a joke for an amp and the $$ they charge for "premium system".
Both my rides will smoke ya 2010 L99 2SS/RS - Hertz HE HSK 165 components/PPI A404 & A600/JL Audio 10W6/Audio Control EQX, FAST Intake Manifold
JohnnyComeLately is offline   Reply With Quote
Old 06-20-2011, 12:30 PM   #9
Dmundz
Dmundz's Avatar
Awesome thanks for the opinions guys.
I think I will swap out the amp and speakers maybe start with the speakers first.
What would you say is best bang for your buck?
Fraxum. You said you didnt have to buy a whole new harness just modify they original harness from ********?
Old 06-20-2011, 01:22 PM   #10
FurySS
Furious Shine
Drives: None
I replaced the factory amp and added subs and sub amp before doing the stock speakers. Although it made the stock speakers sound a little better and louder. Was not happy with the highs and before long I blew one of the stock tweeters (FYI stock door speakers are rated at 50w & tweeters are 20w).
I replaced the stock components with a Polk MM set and it is like an entirely new system. Now I just have the stock 6x9's left but I have them turned down just for "fill". Considering still swapping them out, but not looking forward to that process. New components put out more than enough sound for the entire car.
FurySS is offline   Reply With Quote
Old 06-22-2011, 01:17 AM   #11
Dmundz
Dmundz's Avatar
Well i will definitely replace them all now im thinking just waiting to hear back from steve. to see which harnesses i will need if any. or how i get the initial wiring all figured out. since i will now have my mono amp, and a 4 channel amp.
I'm thinking the kenwood KAC-8405 4 channel amp. but not sure what i want to use for my 6.5 and tweeters.
Old 06-22-2011, 09:56 AM   #12
FurySS
Furious Shine
Drives: None
Not sure if you considered it, but the JL XD400/4 fits perfectly in the spot the stock amp was (using the mounting board Steve supplies). It also has a set of RCA pass-throughs which you can use to connect to your sub amp.
Old 06-22-2011, 11:57 AM   #13
JamiK
Drives: 2011 2LT RS Camaro
Did the 5.1 amp, sub, and enclosure upgrade from ******** and it sounded better. But the BA speakers still sounded like crap. Replaced the front ones with Focal 165v30's, turned down the rear speakers, and now my system sounds incredible.
We are working with against a stacked deck with the "premier audio package" with an underpowered amp and lousy BA speakers.
JamiK is offline   Reply With Quote
Old 06-22-2011, 12:45 PM   #14
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
How did those Focals fit? Where did you mount the tweeter?
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
OK Camaro Experts. What difference does RS package make? Infamous_Racer 5th Gen Camaro SS LS LT General Discussions 32 08-09-2012 02:27 PM
Did anyone get the Factory Installed Subwoofers with Amp. Wvallediego Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 27 04-05-2012 10:52 PM
Will a Spoiler make my ass look Big? PercyJWellingtonIII Cosmetics and Lighting Modification Discussions 24 03-26-2011 08:42 AM
do headers make enough difference Rockman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 50 01-11-2010 10:43 PM
(Replacing Factory 6X9s with Aftermarket) DJ ATOMIX Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 08-18-2009 10:42 AM
