Old 08-16-2009, 01:34 PM   #1
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
Drives: 400HP 2LT/RS
(Replacing Factory 6X9s with Aftermarket)
Today I will simply replace my stock Boston Acoustic factory 6x9s with Pioneer's top end Premier TS-942P 6X9s. Eventually when my sub boxes are built, I will go ahead and rewire to the aftermarket amp for greater preformance. My question is to anyone else who has completed this, how exactly do I get that plastic off in the black window. OMG it looks soo difficult.
After I complete this, I will replace the components in the door which gets complex! I'm just throwing this out there but to anyone who replaced all there in car speakers, did you properly steal signal from ALL four speakers around or did you just splice off the rear speakers? Splicing off the rear speakers kills the front back fade speaker adjustments in the audio controls so you wont be able to make the back louder than the front if you wanted too situation depending.
Shaun
CRAZY BEE - IOM 2LT/RS (more)
Cosmetic Mods - 24 | Performance Mods - 14
ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED
DJ ATOMIX is offline   Reply With Quote
Old 08-16-2009, 03:44 PM   #2
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Why not just use the existing amps wiring harness? Cut the harness off and separate all the wires and just plug them into the new amp when you get it.
BigBOSS is offline   Reply With Quote
Old 08-16-2009, 04:00 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I put in a new amp...I used the existing wires to get to the front components...and I put in new wire for the rear 6x9.
Also you are going to be unhappy when you get to the 6x9 hole, you need to make a nice new mounting plate for them! So get some 1/2"MDF ready, and some dynamat to seal it all up.
As for removing the panel....you need to remove everything around the rear seats, rear windshield area, and to make it easier the rear seat! Then you will finally be able to remove the rear panel. It is prone to breaking or cracking because it has so many darn clips in it. SO be very careful
ZZcamaro is offline   Reply With Quote
Old 08-16-2009, 08:02 PM   #4
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
So after making my first attempt, I failed and placed the clips back in place. It is incredibly hard to get at the 6X9 speakers for removal :( . I couldnt figure out how to remove the side panels from the back seat area as they tuck in and around the door as well.
Shaun
Old 08-16-2009, 09:45 PM   #5
ZZcamaro
Shaun
Yep that ALL has to come out. Basically everything in the rear fo the vehicle has to be removed. Then you have to make a nice mounting point with MDF and dynamat. Then you can finally put it all back together.
To get it all out you will need to pull out the front seatbelts, and the rear seat.
Old 08-16-2009, 11:58 PM   #6
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
ZZcamaro,
I took a good look at the side panels and I couldnt figure out even where to start. Is there a step by step process to this? I'm soo desperate to get those speakers out of there and place in my Premiers. I'm getting fustrated with the process :( . For the record, I managed to take off the four clips that are directly behind the seat connected to the rear panel. I also took off the two clips (one on each side) that hold the carpet in the trunk walls on that are located near the rear seat and they were hard to get to. How many clips???
Shaun
Old 08-18-2009, 10:42 AM   #7
Wood
Drives: 2SS/RS
This thread might have what you are looking for
http://www.camaro5.com/forums/showthread.php?t=36063
Wood is offline   Reply With Quote
AFTERMARKET WHEELS AND TPMS dnr427 Wheels and Tires Talk Sponsored by The Tire Rack 6 07-10-2009 12:35 AM
Aftermarket LT1/LS1 Camaro vs. Aftermarket Mustang GT MrCool 4th Generation Camaros 0 07-03-2009 11:04 PM
Aftermarket upgrades and factory warranty Ahdidah10 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 14 06-07-2009 02:54 PM
Strange but serious question about factory stripes Sean_W Camaro Price | Ordering | Tracking | Dealers Discussions 1 05-28-2009 08:22 PM
Factory Exhaust Option SPECULATION!!!! jmliptak Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-21-2008 11:13 AM
