Old 07-05-2011, 04:55 AM   #1
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
RPI gill insert help.
So I got the RPI ABS gill inserts. They fit ok, but do not conform to the gills very well. The gills are curved and the inserts are flat. The real problem is the adhesive is not strong enough to hold them in the corners.and they keep popping up. They come with 3M but the thin stuff, and I don't want to use the good 3M tape because it is too thick. What would be the best way to get them to stick and stay stuck?
godeepdown is offline   Reply With Quote
Old 07-05-2011, 06:16 AM   #2
montreal2010yellow
montreal2010yellow's Avatar
Need to clean the paint with Methyl Hydrate, won't hurt the paint and will get the wax off.
Old 07-05-2011, 03:39 PM   #3
godeepdown
Jeremy Frye
godeepdown's Avatar
I washed it, hit it with goo gone, and then rubbing alcohol shouldn't that be enough?
Old 07-05-2011, 03:57 PM   #4
montreal2010yellow
Not sure about rubbing alcohol. Methyl Hydrate does'nt have that greasy feeling. But than again i'm no expert.
Old 07-05-2011, 04:36 PM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Rubbing alcohol should definitely be sufficient. I've seen lots of stick on stuff that calls for an alcohol wipedown.
Hopefully someone with those inserts will chime in. It doesn't sound right that they would be flat. That just doesn't make any sense. Maybe you got a bad set?
[B]
Old 07-06-2011, 01:52 AM   #6
H3LL1ON
H3LL1ON
H3LL1ON's Avatar
Drives: 2010 1LT Camaro Synergy Green
I have them and they had a curved shape for sure. Went on easy with soapy water in spray bottle/cloth and they were all labeled :rf,rm,rr. They look great and have taken touchless car washes and the trusty house hose np.
Note: You need to spray gill area with soapy water apply decal and move/stretch into position the using a cloth remove excess water , repeat drying with cloth while holding in position. Also be sure you are applying them correctly according to the labels on the top of each one. No other form of adhesive is needed nor imho recommended.
It's Green, really Green! C5
H3LL1ON is offline   Reply With Quote
Old 07-06-2011, 04:25 AM   #7
godeepdown
Jeremy Frye
godeepdown's Avatar
Do you have the decals or the ABS style? I have the ABS they are like 1/8 inch thick plastic. They are cut to match the gills so they line up but lay flat.
Old 07-06-2011, 12:23 PM   #8
H3LL1ON
H3LL1ON
H3LL1ON's Avatar
Ah my bad i guess i have the vinyl ones. Heres a pic of them anyways.
Old 07-06-2011, 12:49 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
I got the ABS plastic ones and they didn't conform to the gills, so same problem as you're having. Kind of annoying, ended up buying the vinyl ones and putting those on.
Click to view my build thread
Old 07-06-2011, 03:21 PM   #10
godeepdown
Jeremy Frye
godeepdown's Avatar
I was thinking about vinyl but I thought the black ABS would stand out a little better on CGM. They are supposed to be sending me more adhesive so I'll give it another shot, but at this point they look like crap.
Old 07-06-2011, 05:21 PM   #11
CamaroDreams07
Drives: Slow V6
I'm not all that familiar with ABS or working with it, but what about hitting it with a little heat? Would that soften it up a little so you could get it stuck on and then hopefully it would hold the new curved shape?
[B]
Old 07-06-2011, 08:23 PM   #12
svtjackal
svtjackal's Avatar
Drives: 2010 SIM camaro-2001 svt Lightning
the ABS ones are junk, just cut your loses and get the vinyl or the defenderworks ones.
Illinois, Indiana, Wisconsin Camaro Owners check out www.chicago5thgen.com
svtjackal is offline   Reply With Quote
Old 07-07-2011, 04:25 PM   #13
godeepdown
Jeremy Frye
godeepdown's Avatar
Yeah I think that is the key. I am going to take them off and heat them and bend them so they form to the shape then try to reinstall. If they ever send me the new adhesive like they said they would.
RPI Designs Side Vent Insert (Gill) installed Bumble_Bee Cosmetics and Lighting Modification Discussions 50 04-19-2012 08:38 PM
New gill inserts on the Indy Pace car.... InfernoMan2011 Cosmetics and Lighting Modification Discussions 17 04-27-2011 10:34 PM
Retro USA Gill insert mod. daveagogo1 Camaro Photos | Spyshots | Video | Media Gallery 16 02-11-2011 05:50 PM
RPI flaps vs Clear Bra to prevent stone chips Agent WD-40 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 12-16-2010 12:11 PM
Some Defenderworx Gill Insert Pics alexw Cosmetics and Lighting Modification Discussions 4 05-22-2010 02:14 AM
