Old 07-09-2011, 01:35 AM   #1
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Lithium grease.
I am having a hell of a time driving my car with swaybar bushing squeeking & making popping noise as hell & i couldnt find any silicone synthitic grease here
can i use something else like lithium grease or anything to stop this
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 07-09-2011, 01:51 AM   #2
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
I seem to remember seeing synthetic at one of the NAPA stores here. Synthetic is recommended because it won't cause the polyurethane to breakdown.
If you get in a bind, I ordered about 3 tubes of synthetic from Spohn. They carry it and you can order it from them. Not sure about the delivery charges to get to you.
Good luck.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 07-09-2011, 01:56 AM   #3
alssiri
alssiri's Avatar
Good luck.
Thanks, but i am from overseas & most doesnt ship this kind of products cause of shipping restrictions
Ahmad
2012 ZL1 A6 (SOLD)
Old 07-09-2011, 10:28 AM   #4
JusticePete
Drives: Camaro Justice
Squeaking is addressed with grease.
Popping is going to be loose nuts and bolts most likely the endlinks.
If you can't get the right lube, use what you can get. The nuts and bolts are going to be corrected by checking and rechecking the tightness of each one until you have it resolved.
Old 07-09-2011, 01:27 PM   #5
alssiri
alssiri's Avatar
Thanks Pete , but is it ok to use lithium grease insted of silicone grease ?
Ahmad
2012 ZL1 A6 (SOLD)
Old 07-09-2011, 02:44 PM   #6
JusticePete
At the track gorrilla tape, wire and aluminum cans fix almost anything. LOL Sway bar bushes are pretty durable so you should be OK. Did your bars come with new brackets and grease fittings?
Old 07-09-2011, 02:49 PM   #7
alssiri
alssiri's Avatar
Actualy they are Eibach sway bars with new bracket & grease fittings, what happened is that i had a cam swap so the guys here removed the sway bars & cleaned them then but petrolum grease
Ahmad
2012 ZL1 A6 (SOLD)
Old 07-09-2011, 04:01 PM   #8
JusticePete
Ahmad
Those bushes are almost hard plastic and the regular lube shouldn't hurt them. Your warm weather is a contrubiting factor making the grease hot and 'liquid'. Find the best high temp lube and use it as needed.
Old 07-09-2011, 11:16 PM   #9
alssiri
alssiri's Avatar
Thanks Pete >
Ahmad
2012 ZL1 A6 (SOLD)
Old 07-10-2011, 12:05 AM   #10
JusticePete
Thanks Pete >
Ahmad
Now about the color of those bars
Old 07-10-2011, 12:10 AM   #11
PoleCat2SSRS2010
Drives: sometimes
Ahmad
I figured as much but if you ever get a chance.....
Pete,
I agree creativity is the inventor at the track and with all your experience you must be pretty creative...that is a compliment sir. YOU ROCK!
Old 07-10-2011, 02:40 AM   #12
alssiri
alssiri's Avatar
Red
Ahmad
2012 ZL1 A6 (SOLD)
Old 07-10-2011, 09:57 AM   #13
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Look for Marine Grease, you guys got a port every ten feet must be able to find some of that.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 07-10-2011, 10:18 AM   #14
L99CAMA2011
L99CAMA2011's Avatar
I know they should be red huh! LOL.
grease points Cyber/Orange10 Camaro DIY & HOW-TO instructions & discussions 13 03-30-2012 06:48 AM
GREASE ON INSIDE REAR WHEEL!!!! Peter W. Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 03-29-2011 07:08 AM
BMR Trailing Arms Grease oachalon Suspension / Brakes / Chassis 19 12-28-2010 01:20 PM
Grease and tar, etc Tee304 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 9 04-28-2010 12:55 PM
Halltech now carries the Braille Lithium Battery Halltech V8 Bolt-Ons & Tunes 5 12-25-2009 08:51 AM
