Old 07-20-2011, 11:37 PM   #1
Veritasz
Drives: 2010 Camaro
JBL MS 8.
Has anyone installed a JBL MS 8 in a camaro using the factory head unit. I'm curious what the results were if you have.. I'm thinking that this may be the route I take when upgradeing..
Veritasz is offline   Reply With Quote
Old 07-21-2011, 04:46 AM   #2
nashstat
Drives: 2SS Camaro
I have done it and the results are good. I also have a subwoofer installed in my car with an Alpine amp powering it as well.
The MS-8 really brings more life out of the stock speakers. The biggest advantage of the MS-8 is the 32 band EQ it features. Huge difference in the sound.
nashstat is offline   Reply With Quote
Old 07-21-2011, 07:13 AM   #3
SWRocket
SWRocket's Avatar
Drives: 2021 2SS
I have it along with amps, sub and components. It's very easy to set up and the results are amazing.
SWRocket is offline   Reply With Quote
Old 07-21-2011, 05:53 PM   #4
Veritasz
Drives: 2010 Camaro
I'm assuming you all are using the factory radio. Do you have any problems with turn on pops or noise of any kind using this unit. I want to build a syatem using this unit and the factory player..
Old 07-21-2011, 06:07 PM   #5
mpyle007
mpyle007's Avatar
Drives: 2011 Camaro 2SS L99
Whoa whoa is the MS-8 out? I was at the Harman Facilities when this piece was in testing. Andy Whemeyer did a demo is a dodge neon. This piece changes what car audio is all about. Takes any and I mean any system and makes it sounded amazing.
I want! I'm calling the guys at JBL tomorrow.
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop
TSP Long tube headers w/ high flow cats and full x-pipe
GMPP axle back exhaust system
Custom Dyno tune by ARD (Advanced Racing Dynamics)
BMR 1.4" Springs all four corners
"There is no replacement for displacement"
mpyle007 is offline   Reply With Quote
Old 07-21-2011, 06:31 PM   #6
tbone587
Drives: 2011 Camaro
With this processor arent you required to use their display to control the volume?
tbone587 is offline   Reply With Quote
Old 07-21-2011, 06:53 PM   #7
SWRocket
SWRocket's Avatar
Drives: 2021 2SS
I am using the stock HU. I do not have any turn-on pop or noise. I am not sure where the turn-on is connected to, but they told me its from the stock amp (I have the Boston Accoustics.) I do know that the speaker outputs from the BA amp are connected to the high level inputs on the MS-8 and I believe the MS-8 senses when there is signal on those inputs and turns on.
Old 07-21-2011, 06:53 PM   #8
1FAST SS
1FAST SS's Avatar
Drives: 2011 Camaro SS
I installed the MS-8 with Alpine PDX amps, JL Audio comp in doors and rear deck,and Alpine T10 Type R shallow mount subs. Sounds great. Had turn off pop, but did some tweaking and it went away. You will love it once you get it set to your preferences.
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery
1FAST SS is offline   Reply With Quote
Old 07-21-2011, 06:55 PM   #9
SWRocket
SWRocket's Avatar
Drives: 2021 2SS
No, you are not required to use their control. You CAN use their control which has volume, tone and balance controls as well as a 31 band EQ.
I have the MS-8 volume at -15 and the tone at 0 for bass, treble and mid and I use the volume and tone controls on my HU (the stock one) for everything. Their controller comes with a little remote control that is pretty cool, so if you have room to mount their display somewhere you can use the remote.
Old 07-21-2011, 08:28 PM   #10
Veritasz
Drives: 2010 Camaro
Thanks guys for the response..I'm planing to do something in this camaro that is a little unconventional using jl audio,scan speak and seas excel..
Old 07-21-2011, 09:57 PM   #11
tbone587
Drives: 2011 Camaro
ciandrew, so you are saying it is not even required to permanetely mount the ms-8 display? Does the processor make that much of a difference? I have a jl audio hd600/4 and 750/1. Where is your ms-8 processor mounted?
Old 07-22-2011, 07:20 AM   #12
SWRocket
SWRocket's Avatar
Drives: 2021 2SS
My processor is in the trunk, along with the amps and the controller is in the centre console but not mounted. I only used it for the setup. Depending on your preferences, you may spend much more time playing with the EQ so you may use it more.
Old 07-22-2011, 07:51 AM   #13
tbone587
Drives: 2011 Camaro
Can you take a picture of it by chance? And also does the controller have to be plugged in for it to function, or can you do the initial setup and then unplug it?
Old 07-22-2011, 04:37 PM   #14
Veritasz
Drives: 2010 Camaro
According to the JBL literature the display screen can be removed after set up is done if you like. You do not have to permanently mount it. The only thing is you have to plug it in if you want to change settings..
Difference between AudioControl EQX Equalizer w/ Crossover vs JBL MS-8 Edscapade Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 05-02-2011 05:46 PM
MY JBL MS-8 Review (long read) nashstat Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 05-01-2011 04:46 PM
JBL MS-8 vs All others nashstat Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 10-09-2010 07:13 PM
Sound Processor Questions. JBL indigloflow Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 08-08-2010 11:46 PM
Decided to go JBL The 2010 Sin Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 48 06-03-2010 08:29 PM
