Old 08-01-2011, 06:36 PM   #1
gatorlover
gatorlover's Avatar
Drives: 2013 AGM 1SS/RS 1LE
Another cam question
Ok guys and gals, I just received a quote for a cam and wanted to get some opinions on the specs and such.
First let me level set by sharing the current mods on my car.
2010 2ss L99
K&N cold air intake
1 7/8 XSpower long tubes with cat delete connection pipes
Borla "s" type catback 2.5"
Jannetty Tune
As for the quote, this is what it includes:
3 bolt cam 225/230 .617 / .612 112 LSA
Remove and
Replace Camshaft, Requires
DOD/VVT Delete Lit and
Installation-Remove and Replace
Lifters,Valley Cover, Head Gaskets
Naturally Aspirated Electronic Fuel
Injection Tuning
GM VVT Delete kit-Engine Front
Cover Gasket
DOD Delete Kit-LS7 Lifters,
Valley Cover, Lifter Trays, Head Bolts
Camshaft, Pushrods, Double Valve
Springs, Valve Seats, Valve Seals,
Water Pump Gaskets, Timing Cover
Gasket, Front Cover Seal, ARP
Crank Bolt
GM MLS Cylinder Head Gasket
8 Quarts Oil, Oil Filter, Coolant
Curious if anyone else has a cam like this and what are your thoughts on how it will behave as a daily driver.
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced)
gatorlover is offline   Reply With Quote
Old 08-02-2011, 06:35 AM   #2
gatorlover
gatorlover's Avatar
anyone?
(1 of 43 produced)
Old 08-02-2011, 08:16 AM   #3
steeleshark2
steeleshark2's Avatar
Ever thought about getting your heads done since they will already be off?
Old 08-02-2011, 08:33 AM   #4
Parapdrapa
Drives: 2010 Camaro
That cam will be very streetable. Good manners and good power below 230/230 .620/.620 u still need a good tune so make it so
Parapdrapa is offline   Reply With Quote
Old 08-02-2011, 08:36 AM   #5
gatorlover
gatorlover's Avatar
Well, biggest challenge right now is funds to do what I was quoted. I'm really early in my research so we shall see.
(1 of 43 produced)
Old 08-02-2011, 08:55 AM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Looks like everything is covered... might want to think about a Torque Converter too but if funds are a concern why not just leave the heads on for now and put in a VVT cam. You can still get the nice lope and keep it very streetable.
That would save a few $$$ and get you the same results...
mlee is online now   Reply With Quote
Old 08-02-2011, 09:25 AM   #7
gatorlover
gatorlover's Avatar
Interesting thought. I will need to do some research on those. So that would negate having to do the ls3 conversion correct? I'm still learning so I apologize if thats a stupid question.
(1 of 43 produced)
Old 08-02-2011, 10:07 AM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Yes it would. Since you are doing a smaller cam with no Torque Converter I would definitely look into just putting in a VVT cam. Lot's of good threads around here and there are some good power benefits to keeping VVT. There is only really one downside and it's keeping the stock lifters but they make VVT cams that are lifter fiendly.
Old 08-02-2011, 12:03 PM   #9
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
The problem with DOD lifters is that you are limited to .500" lift and can't really take advantage of how well the heads flow, being that the LS3 has .551" from the factory and much of it's power difference is because of that.
Chris@SPMC is offline   Reply With Quote
Old 08-02-2011, 12:36 PM   #10
steeleshark2
Torque Converter is the best bang for buck. You could also go with a bigger cam if you had one. Only my opinion, I would do the LS3 conversion.
Old 08-02-2011, 02:15 PM   #11
Patrick G
Drives: 2009 Pontiac G8 GT
You can get a VVT cam with high lift, but you'll need to replace the DOD/AFM lifters. Going phaser-only is a solid plan for broader power under the curve. VVT is a real performance advantage if your installer/tuner knows how to work the right combo.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Hot Cam install question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 02-21-2011 12:23 AM
cam swap question paslag Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-30-2010 08:55 PM
LS3 cam question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 05-04-2010 06:41 PM
Cam question Gunsmoke Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 04-17-2010 05:38 PM
Cam gear question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-16-2010 08:01 PM
