Old 08-17-2011, 09:50 AM   #1
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
2012 SS L99 fuse pull
Just turned 800 miles on my vert and filled it up for the 4th time. Was wondering if the fuse pull would wake it up. So last night the storms rolled in so I parked it and pulled the fuses. Put them back in this morning and man did the motor wake up. In D mode it pulls way quicker. In M mode I got on it and the back end broke loose and sent me a little sideways even with the nannies on. Plus it chirped going into second. This car is a beast.
Dealer said he put in 92 when I picked it up. Now I doubt it.
If you have a 2012 L99 I would pull the fuses. I'm now a believer.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 08-17-2011, 03:50 PM   #2
SLASH
SLASH's Avatar
Drives: F150/1SS/benz
good call
2012 Benz E-class coupe
2012 Red Camaro 1SS
2011 Ford F150 king ranch 4x4
SLASH is offline   Reply With Quote
Old 08-17-2011, 04:27 PM   #3
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Wow, you'd think GM would've fixed this by now.
E.T. is offline   Reply With Quote
Old 08-17-2011, 07:07 PM   #4
Mark1SS
Drives: 2012 1SS Delivered!
What fuses did you pull?
Also, how's the ride compared to the 2011?
Mark1SS is offline   Reply With Quote
Old 08-17-2011, 07:10 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Fantastic, enjoy the ride..
Old 08-17-2011, 07:14 PM   #6
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=38964
Make sure the engine and ignition are turned off
Locate Fuse Panel in front of the passenger's side front strut tower and pull the cover
Remove #5 and #20 (15A fuses) (photo of location below)
Let the car sit for at least several hours (overnight is preferable)
Install #5 and #20 (15A) fuses
Install Fuse Panel cover
Restart vehicle and enjoy
Note: Do not unplug the battery. It has no effect.
Old 08-17-2011, 07:32 PM   #7
Black5thgen
Drives: 2007 C6
There's nothing to fix. You put 87 in and it pulls timing to counter for less octane so the engine doesn't knock. Once 87 is in it locks in the lower octane fuel table.
Black5thgen is offline   Reply With Quote
Old 08-17-2011, 07:58 PM   #8
E.T.
E.T.'s Avatar
Yeah, but the car's computer should be smart enough to know when higher octane is in again, and switch to the higher table. Imagine someone who didn't know any better and was driving around on the low fuel table all the time.:(
Old 08-17-2011, 10:22 PM   #9
1CamaroSS
1CamaroSS's Avatar
Drives: 2011 Camaro 1SS Inferno Orange
Are you serious? I did not know this but then again this is first Chevy I have owned in 18 yrs. or so. In the upper midwest we can get 10% ethenol at 89 octane for .10 cheaper than 87 octane. So I usually run the 89 Octane. I filled up last week with 93 octane and took an out of town trip. I didn't notice much power increase but I did notice about 23mpg @ 85-95 mph instead of 20mpg or so. Our speed limit here is 75 mph.
1CamaroSS is offline   Reply With Quote
Old 08-17-2011, 11:25 PM   #10
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
89! 93 only! or there'll be trouble. But yeah low octane cut's the nards off the V8 auto. So Filler up and Fuse pull. Then hold on.
9/26/09 Took delivery!
Old 08-17-2011, 11:32 PM   #11
95birdible
95birdible's Avatar
Rides great. Then again the only time I drove another one was in 10 and that was a hardtop. Nice and smooth. Bumps are really not a factor. Suspension is stiff in the convertible but not to much. Rides and corners great. The cornering reminds me of my neighbors 07 Vette.
"Cherry Bomb"
"Green Flash"
Old 08-18-2011, 01:48 AM   #12
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Just wondering, I know that the fuse pull works for the higher octane gas, but what happens when you use lower octane and do a fuse pull?
SamHouseIII is offline   Reply With Quote
Old 08-18-2011, 06:39 AM   #13
orangeandwhite
orangeandwhite's Avatar
Drives: 2010 2SS white with orange stripes
You waste a few minutes of your life I guess....
orangeandwhite is offline   Reply With Quote
Old 08-18-2011, 07:38 AM   #14
E.T.
E.T.'s Avatar
Uh oh, I think you are really missing out on your car's potential!From what I've read on here, you gotta run a few tanks of high octane to make sure all the lower octane stuff gets used up, then do the fuse pull. I don't have the SS, so one of those guys can probably give you more info
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2838 05-12-2024 12:42 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
Fuse pull for low octane fuel fix Kman 2011 ss 5th Gen Camaro SS LS LT General Discussions 11 03-30-2011 10:28 AM
Fuse Pull - Other GM Vehicles L99SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-19-2010 04:06 PM
