Old 09-14-2011, 01:56 PM   #1
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2020 2SS/M6) (2025 GMC Yukon)
Question DISABLING THE NANNIES?
Does anyone know if there's a way to make the TC and StabiliTrak systems default to "off" instead of "on"? I'm tired of having to hold the button down for seven seconds every time I start the car.
Nanny controls, AFM, skip shift...etc. Big brother is ruining the automobile industry in America.
kmcd is offline   Reply With Quote
Old 09-14-2011, 02:13 PM   #2
siriusdish
Drives: 2010 Camaro L99
Originally Posted by kmcd View Post
Does anyone know if there's a way to make the TC and StabiliTrak systems deafault to "off" instead of "on"? I'm tired of having to hold the button down for seven seconds every time I start the car.
Doesn't the Tune take care of it??? My Dad never uses it, does not seam to make a differences to us.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 09-14-2011, 02:13 PM   #3
11BEE
11 BEE
Drives: 2011 LS2 RS & 2012 2SS RS 45th Vert
I would be interested in this as well.
11Bee and I♥My45th
11BEE is offline   Reply With Quote
Old 09-14-2011, 02:30 PM   #4
kmcd
kmcd's Avatar
I have a dyno tune, but I did'nt think to ask the tuner to modify the nannies. I don't even know if you can (hence the reason for this thread). I'm not trying to disable them completely. I just want the default status to be "off," instead of "on." I suppose if I had to disable them permanently, I might be open to that.
I hate the fact that they kick in every time I floor it. It's especially embarrassing when I forget to disable them at the track.
Old 09-14-2011, 02:54 PM   #5
Parag
Drives: 2010 camaro 2SS LS3
I want to know this as well, i was told by someone to pull fuses. I am getting a dyno tune in a week and want ro know what to ask tuner. I am also removing side airbags, can the tuner disable the warning lights?
Parag is offline   Reply With Quote
Old 09-14-2011, 03:28 PM   #6
GoldBowtie
GoldBowtie's Avatar
Drives: 2021 Yukon Denali, 2018 ZL1
Don't forget to remove the seatbelts!
2018 ZL1
GoldBowtie is offline   Reply With Quote
Old 09-14-2011, 04:01 PM   #7
kmcd
kmcd's Avatar
...I am also removing side airbags, can the tuner disable the warning lights?
Old 09-14-2011, 04:04 PM   #8
CFD
Drives: 2SS/RS L99 BLACK
That would be great, it's a pain in the butt turning them off.
CFD is offline   Reply With Quote
Old 09-14-2011, 04:56 PM   #9
BadAssBumbleBee
BadAssBumbleBee's Avatar
Drives: 2010 Callaway SC572
SLP made a TCS reversal module for the 4th gen F-Body..........maybe a few dozen e-mails to them will help encourage them to make one for the 5th gen.
Steve
2010 Callaway SC572
2019 Jeep JL Rubicon
BadAssBumbleBee is offline   Reply With Quote
Old 09-14-2011, 05:19 PM   #10
kmcd
kmcd's Avatar
That would be the ticket! That way you could still turn them on in bad weather if you wanted.
Old 09-14-2011, 07:49 PM   #11
siriusdish
I think my Dad's are turned off, HP tuners. Man I feel no differences when holding that button down other then seeing the lights on the dash. Could be wrong.
2010 L99
Old 09-14-2011, 07:50 PM   #12
siriusdish
What Do U mean by this???
2010 L99
Old 09-14-2011, 07:59 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Stabilitrak and some of the tcs are controlledby the ebcm, no tuning suite will be able to touch that stuff. You can disable the power reduction part of the tcs in the ecm, but even with that disabled, the stabilitrak will still apply some brake pressure on the rears to try and stop/control the wheelspin. In most cases it will power through that.
Holding the button is the only way as of now, to fully disable it, OR pull the ABS fuses at the track. Be aware the brakes will suck with the fuses pulled, but there will be no stabilitrak assist.
Rhino79 is offline   Reply With Quote
Old 09-14-2011, 08:03 PM   #14
siriusdish
Good to know. Just do not feel any thing different. Well Understandable?
2010 L99
Rain + nannies off = .... IROCanSS 5th Gen Camaro SS LS LT General Discussions 77 09-11-2011 11:30 PM
Who has been successful at completely disabling DRLs? Callaway Chris Cosmetics and Lighting Modification Discussions 7 03-07-2011 11:41 AM
Disabling DRL - BCM Function Delete H3LL1ON Canada 17 02-19-2011 03:13 AM
Possible Federal Mandate for More Nannies in our Cars greenrail 5th Gen Camaro SS LS LT General Discussions 28 03-09-2010 07:22 PM
Brake Torque & Electronic Nannies Tomato 5th Gen Camaro SS LS LT General Discussions 3 08-15-2009 12:31 PM
