Old 09-18-2011, 08:29 PM   #1
TrackZero
TrackZero's Avatar
Drives: 2010 Camaro SS
Smallest widest rim that we can run on an SS
Hello everyone, I am hoping someone knows this info. I am trying to find out what rims I can run. It looks to me that I could run an 18" from some of the posts here, but does anyone know what the width I can run is? I am looking at a few on ebay that are c6 Z06 wheels. some are 9.5 and some are 10.5. Just wondering if I can run either. Any thoughts or comments are appreciated.
I need to get some Drag Radials, after my super poor showing at the track Friday night.
Thanks
JR
2010 IOM SS - CAI, VMAX ported Throttlebody, ARH Longtubes to tailpipe Yank 3600SS Torque Converter, GPI SS4 VVT cam, Custom tune by Rhino79
TrackZero is offline   Reply With Quote
Old 09-18-2011, 08:44 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You can run either of those as long as its the right offset. I run 18x11 on the rear.
SUX2BU is offline   Reply With Quote
Old 09-18-2011, 08:50 PM   #3
TrackZero
TrackZero's Avatar
Do you happen to know what the correct offset would be for either the 9.5 or 10.5's?
Old 09-18-2011, 11:16 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It's been mentioned a lot on here, just search it. I want to say it was 40 mm. Most Vette wheels are like 53 or 58, so be careful that you buy the right ones.
Old 09-19-2011, 10:01 AM   #5
Black5thgen
Drives: 2007 C6
Most Vette rims are 54, you need a +40 to fit the rear. The only Vette rims that have that offset are C6 grand sport, Z06 and ZR1 front rims. I made the mistake of getting C5 Z06 rear rims with a +56 offset and they didn't fit without a spacer.
Black5thgen is offline   Reply With Quote
Old 09-19-2011, 10:48 AM   #6
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Several guys here in h-town are running the C5 Z06 rear wheels in 18 x 10.5 with a 53mm offset. This offset fits perfect on the rear with a 305/45/18 or a 305/35/18 and no spacer required. You do however need to zip-tie the e-brake cables back a bit.
There's at least 9 or 10 Camaros here with that set-up and mine is coming in this week sometime
Hope this helps
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 09-19-2011, 12:03 PM   #7
TrackZero
TrackZero's Avatar
Thanks for the info. Now I just need to find a good place to get the new rims from.
Old 09-19-2011, 07:04 PM   #8
TrackZero
TrackZero's Avatar
Well here is what I ordered, hopefully it all fits with no issues
Rims - http://www.amazon.com/gp/product/B004SN7ZWQ
Tires - http://www.discounttire.com/dtcs/findTireDetail.do?r=ILCINT|pc|60031&pc=40584&ar=45 &rd=18&cs=305
I'll let you all know how it works out.
Old 09-19-2011, 07:12 PM   #9
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You ordered the wrong wheels. Those have a 56mm offset you will will need to run a spacer on the rear and spacers are not safe, especially for any kind of racing.
Old 09-19-2011, 07:37 PM   #10
Eric Baker
Drives: Black/Black 2SS/RS 6M
Which wheels then? I'm looking to buy something this week for racing the first two saturdays next month. Almost pulled the trigger on the 17" welds yesterday, but really can't afford that ~$3000 right now. Looking to get some 18's and MT ET Street Radial II's.
I've seen people posting about vette replica wheels, but can't find anything with the correct offset, and am still unsure about the bolt pattern, as many people say the extra .65mm is too much to fit correctly.
Eric Baker is offline   Reply With Quote
Old 09-19-2011, 10:37 PM   #11
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
I fit these with 295/45 nitto NT05s on all four corners.
http://www.camaro5.com/forums/showthread.php?t=154699
They did well at this past weekend's Autox. It was my first one.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 09-19-2011, 11:54 PM   #12
TrackZero
TrackZero's Avatar
Well, that sucks, I am going to try and fit them, just to make sure. But if they do not work, I'll place an order for these. Assuming they will work.
http://www.amazon.com/gp/product/B004SOAGEE
Old 09-20-2011, 12:08 AM   #13
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Those would work a lot better. With such a tall tire as the 305/45 18 your wheel/tire combo may bolt up fine but will more than likely rub when you take corners.
Old 09-20-2011, 08:28 AM   #14
Black5thgen
Drives: 2007 C6
I have a set of spacers that will work with them I could sell you. I just need to find them.
What is the widest sized rim the stock rims can fit? Powhusku Wheels and Tires Talk Sponsored by The Tire Rack 3 08-10-2011 03:38 PM
Stock SS Parts – AZ Available edneyens Local Marketplace 5 05-16-2011 08:58 PM
Are they rims or are they wheels?? topgun1 Off-topic Discussions 28 07-07-2010 12:02 AM
Widest tire to fit stock SS rim? LibLoather Wheels and Tires Talk Sponsored by The Tire Rack 8 05-28-2010 11:36 AM
Will the SS have 20" run flat tires? Can we go bigger in size? Hoss Wheels and Tires Talk Sponsored by The Tire Rack 18 11-28-2008 11:59 PM
