Old 10-24-2011, 10:54 AM   #1
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
need advice on coilover install
Dear friends i just got me pfadt coil over kit. I decided to get brave and install it solo.. I did the fronts, but I see that I need a bushing remover of some sort for the rear stock rear coil over. Can anyone tell me tool that is and where I can find it...your help is much appreciated. (The directions say to remove the stock bushing near the end of the shaft where it meet the top chassis)
ipimpthisc is offline   Reply With Quote
Old 10-24-2011, 11:06 AM   #2
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey there. The process can be a little tricky the first time you do it, but not impossible with hand tools. here are a couple threads which may help you:
Avalnch Thread using block of wood, and washer + nut as a drift
You could also cut it out using a sawzall or other cutting tool, a couple strategic cuts in the shape of a pie wedge should remove enough material that the bushing will collapse on it's self. Just be careful not to nick or cut into the upper mount it's self. Ultimately if you're having a really tough time with it the entire process is really simple with a press. Take it down to your local machine shop and they should have the bushings removed for you in about 15 minutes.
If you have any other issues let us know! We're here to help.
Old 10-24-2011, 11:08 AM   #3
PfadtRacing
With our custom rear upper mount system you will remove the bushing in the rear upper mount. What we replace that rubber bushing with is basically a super durable spherical bearing that's captured by 2 retaining plates that bolt with 5 set screws into each other and sandwich the metal of the upper mount.
Old 10-24-2011, 11:11 AM   #4
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I was just sending a PM to you guys to come in here...
Deleted my post... I was thinking springs not coilovers. My mistake.
Old 10-24-2011, 11:14 AM   #5
ipimpthisc
Banned
thank you all...but is there a tool i can buy...do i have to bring to some one...i dont really know who to bring it too...so its a must do for me...and i rather a nice thing instead of butchering my stuff...i am good i destroying stuff when i invent.lol
Old 10-24-2011, 11:18 AM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
This should do the trick... you just need a long bolt couple washers and a solid piece of wood
Lowes or Home depot should have everthing you need.
Old 10-24-2011, 11:22 AM   #7
PfadtRacing
Well your best option if you're doing it by yourself is either with a press, or a trip to Lowes and come up with something like what Avalanch did. Buy a long bolt, washer, nut, and block of wood. Drill a hole in the wood so you have something to thread the bolt through. Once the bolt is through both the wood and the bushing begin to tighten the bolt until it pulls the bolt head and washer through the under side of the upper mount, taking your rubber bushing along with it. Past that the correct tool is a press.
If you get stuck with it just look up machine shops in your area on Google. Even the most modestly of equipped shops will be able to get that bushing out for you really quickly.
Old 10-24-2011, 08:07 PM   #8
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
if your cell phone broken!!! dude you could of called i was in the shop all day!
camaro4mybday is offline   Reply With Quote
Old 10-24-2011, 09:22 PM   #9
ipimpthisc
Banned
Thanks everyone and thank you joey z...i ended up goin to my friends shop and gettin it pressed out real easy...but install the rears is no joke..the height situation is the worst. Just took it for a spin and heard a loud bang in the back...now i am nervous...thinkin what did i do wrong...but Joey I wanted to do myself...a pride thing
Old 10-25-2011, 08:08 AM   #10
GTAHVIT
Blessed
GTAHVIT's Avatar
I'm sure they'll get you sorted out... I totally understand the pride thing...
Old 10-25-2011, 06:21 PM   #11
ipimpthisc
Banned
ok I rechecked all the stuff...all is good...my car just has so much power that it bangs things in the truck and i though i broke an axle or something. Again thank you all for the advice out here. I am happy with the suspension. I will make a new thread based on my impressions soon.
Old 10-25-2011, 10:08 PM   #12
camaro4mybday
"Camaro Joe"
its no problem bro!!! it isn't always about business! if i can help with some advise or a quick fix you know where I'm at! now we need to get the major part of your suspension done! rear bushings!!!
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
Install of new Pioneer AVH-P3300BT with painted black Metra kit Darth Martel Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 09-13-2011 09:50 AM
Rear Coilover Install Question??? blazzin1 Suspension / Brakes / Chassis 7 04-06-2011 09:17 PM
How-To on how to install AAC sidemarkers? crewxp Cosmetics and Lighting Modification Discussions 23 02-23-2011 10:31 AM
2010 GT500 Sub Install SuperFly03 General Automotive + Other Cars Discussion 8 01-15-2011 05:25 PM
