Old 11-16-2011, 01:02 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Painted door ABL panels
Has any one repainted the inside of there ABL panels , And the ABL still work's,
I only want to know if its painted in the inside......................
Old 11-16-2011, 03:29 PM   #2
2SSRS@Gen5diy
No One ? WOw so i got a single door trim and striped the paint off, then used 400 grit then 600 and 800 then last i stopped with 1200 grip, all wet sand paper, then i repainted the inside, so it drying and will be ready to see if its good late today., If it is then you can make any color you want.
Old 11-16-2011, 03:33 PM   #3
Jermola23
Drives: 2011 black camaro
i painted the outside of the door panels gloss black. what do you mean inside??
Jermola23 is offline   Reply With Quote
Old 11-16-2011, 03:34 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes it can be done. But it's a trick getting the paint to stick.
He's talking about the other side of the door panel, the side that faces the inside of the door. So if you painted the "outside" of the panel, then the "inside" is the other side of the panel.
Click to view my build thread
Old 11-16-2011, 03:37 PM   #5
2SSRS@Gen5diy
Well only time will tell, as of right now its grate, and if its going to work like i want, it will be my test unit for two things, one is the RGB ABL and then for the rear ABL.
Old 11-16-2011, 04:48 PM   #6
The Stig
The Stig's Avatar
Cool. Yea painting it from the "inside" gives it depth. I remember your rear ABL idea. You've got a spare panel lying around for that if I remember right. But I'll keep my mouth shut, don't want to ruin the surprise.
Old 11-16-2011, 04:53 PM   #7
camaro2lt
camaro2lt's Avatar
do you still want my panels if it does not work?
Old 11-16-2011, 05:39 PM   #8
Spencer@EH
Spencer@EH's Avatar
Drives: 2010 Yellow RS
The door panels are infact painted from the inside. Ive done it on the outside with a carbon fiber hydro dip on the outside and the only trick is finding exactly where the ABL comes through and taping that part off. As long as you sand it really really well, and use K2 primer, you wont have any issues. Its all in the prep work you do. Its best to have it done professionally.
Spencer@EH is offline   Reply With Quote
Old 11-16-2011, 05:51 PM   #9
2SSRS@Gen5diy
Thanks for that, your right prep is how to make it right, camaro2lt Yes its that or i need new ones.
Old 11-16-2011, 07:36 PM   #10
camaro2lt
camaro2lt's Avatar
this is going to be a cool mod.......
Old 11-18-2011, 03:49 PM   #11
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
The inside of panels have a slight green to change the ice blue to green. If I get your RGB ABL would I need the whole thing painted or could I use paint remover on the top part of the door panel
Sent from my Droid using Tapatalk
Synerbee is offline   Reply With Quote
Old 03-26-2012, 09:03 PM   #12
Slomo051
Slomo051's Avatar
Drives: 2011 2LT/RS
2SSRS...I take it painting the inside of the door panels was a success and you retained ABL? I'm looking at attempting the same thing. Was it difficult removing the paint?
Thanks!
Slomo051 is offline   Reply With Quote
Old 03-26-2012, 10:47 PM   #13
2SSRS@Gen5diy
It was hard, you will need to wet sand the inside.
Old 04-27-2012, 07:58 AM   #14
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Can anyone who has removed inside door panels can advise if these self drilling or tapping screws will work for reapplication?
I picked up self drilling screws #8x 3/4" hex head and there are four in the pack. I also got #8 x 1/2" self drilling screws with hex head, 100 in the pack and I also picked up a pack of washers to cover each application for each door panel.
Thanks~!
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Painted Rally Stripes - Cost Estimates? rolnslo Cosmetics and Lighting Modification Discussions 32 04-06-2011 10:26 AM
FS: Silver Door Panels (SOLD) TAG UR IT Interior Parts & Accessories 19 01-07-2011 12:15 AM
Painted Door Panels / Dash Inserts motomediafx Cosmetics and Lighting Modification Discussions 5 01-02-2011 05:29 PM
Custom Painted Stripes Underway for Bumleb's Rally Yellow 2SS RumbleBeeSS Cosmetics and Lighting Modification Discussions 140 06-20-2010 12:12 AM
Who has the LS3 painted engine cover alfie43 Cosmetics and Lighting Modification Discussions 13 08-27-2009 06:42 PM
