Old 11-25-2011, 05:45 PM   #1
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Calibrating Compass
Had the car in a parking garage for most of the day today. When we came out onto the main road, I see "CAL" in the lower left side of the HUD. I figured it meant "calibrate" & the owner's manual says to "Drive the car a short distance and the GPS will automatically calibrate."
We drove for about 15 miles & it still keeps reading "CAL" - anybody know of a fix to reset the compass?
classicrockr is offline   Reply With Quote
Old 11-25-2011, 06:19 PM   #2
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
Compass and GPS are two different things. To calibrate the compass drive slow figure-8's in a parking lot somewhere. To calibrate GPS you just drive, preferably straight and level. It helps both if you do this away from big buildngs and other potential interference.
Sounds like your issue is compass, so try some figure-8's.
Flashpoint135 is offline   Reply With Quote
Old 11-25-2011, 06:33 PM   #3
jtzako
Drives: 2010 IBM Camaro SS
I get CAL on the compass sometimes, normal driving will usually fix it as long as it involves some turns. If I see it come up I just got he long way out of my neighborhood which involves 3 right turns to get to the main street, by that time it has calibrated.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 11-26-2011, 08:14 PM   #4
classicrockr
tried the figure 8's & driving around the block - compass still reads "CAL"...guess i'll have to have the service department fix it...
Old 11-26-2011, 08:22 PM   #5
IROCanSS
Drives: 89 IROC 350
Time for a trip to the dealer. 10 to 1 it fixes itself on the way there. Probably as you turn in the dealership lot.
Old 11-28-2011, 10:37 AM   #6
DerekT
Drives: 2011 Camaro 2LT/RS Inferno Orange
I bought my Camaro in Ontario and drove it back home which involved a 12-hour ride in the cargo bay of a ferry. When I drove out, I had the same problem.
Apparently, it has something to do with the OnStar system, something called "dead-reckoning" (or something like that). I popped the OnStar fuse out my fuse panel, waited about 5 minutes, popped it back in, drove it for couple of miles and then it was fine.
DerekT is offline   Reply With Quote
compass not displaying cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-15-2014 06:01 PM
In dash compass "CAL" fishbrownie USA - Texas 12 03-29-2013 03:45 AM
Test Drive 2011 Jeep COmpass trail rated Stew General Automotive + Other Cars Discussion 5 06-12-2011 08:54 PM
DIC Compass Problem on 2SS GRSCAMARO Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 15 02-21-2011 03:37 PM
Compass ZCT 5th Gen Camaro SS LS LT General Discussions 18 12-21-2010 07:24 PM
